[OpenLayers-Users] Help with Strategy.save and protocol.http
Eric Lemoine eric.lemoine at camptocamp.com
Thu May 20 08:04:17 EDT 2010
On Thu, May 20, 2010 at 9:02 AM, Frank Broniewski <brfr at metrico.lu> wrote:
> Hello Eric, all,
>> The save strategy just calls protocol.commit(). See
>> <http://trac.openlayers.org/browser/trunk/openlayers/lib/OpenLayers/Strategy/Save.js#L178>.
>> The protocol's commit method looks at the states of the features and
>> calls the appropriate method (update/create/delete). See
>> <http://trac.openlayers.org/browser/trunk/openlayers/lib/OpenLayers/Protocol/HTTP.js#L519>.
> If it "just" calls protocol.commit(), what's the reason for having a
> save-strategy? Is it to have some kind of user - frontend to the protocols
> methods? If I don't use the save-strategies autosave feature, there's for me
> no difference wether I call protocol.commit() or strategy.save().
Look at the onCommit method in the strategy, it does some work.
> Or is
> there something more to using strategy.save() or strategies in general?
> Something like: "Don't use protocols directly, it is preferred to use them
> through strategies.", thus a design decision?
To me there's no such principle.
> From looking at the code ;-) I see that there is a projection check and an
> optional transformation to the remote projection, so that would be the
> "only" difference before protocol.commit(), right?
onCommit does other things.
> I presume, the
> transformation is mostly there for the google projection (900913) to wgs84
> transformation, or does OpenLayers have already some kind of proj support
> built in?
OpenLayers can be used with proj4js.
Cheers,
Eric Lemoine
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel : 00 33 4 79 44 44 96
Mail : eric.lemoine at camptocamp.com
http://www.camptocamp.com
