[OpenLayers-Users] GetFeatureInfo returns attribute name only(Mapserver & Openlayers)
simi cserumola at yahoo.co.uk
Mon May 24 04:14:16 EDT 2010
I have been trying for a long time(since february 2010) to use GetFeatureInfo
to display the attributes of a clicked polygon feature . The map is
displayed in OpenLayers 2.8 which uses a mapserver 5.6.1 for the mapfile
whose data source is a shapefile. When i click on a polygon feature, i only
get the attribute name "[NAME]" (as it appears on the html body template
file) AND not the atrribute values. Please help.Here is the openlayers file
contents;
<html>
<head><title>OpenLayers project</title>
<style type="text/css">
        #map {
            width: 800px;
            height: 600px;
            border: 1px solid black;
    </style>
<script src="http://openlayers.org/api/OpenLayers.js"></script>
<script type="text/javascript">
function init() {
var map = new OpenLayers.Map('map');
var dcs = new OpenLayers.Layer.WMS(
'Admin Districts',
'http://localhost/cgi-bin/mapserv.exe?map=C:/ms4w/Apache/cgi-bin/Districts2.map&',
{layers: 'Botswana_Admin_Districts'}
map.addLayer(dcs);
map.setCenter(new OpenLayers.LonLat(25,-24),6);
// Tie click event to WMS GetFeatureInfo call
map.events.register('click', map, function (e) {
    var url =
"http://localhost/cgi-bin/mapserv.exe?map=C:/ms4w/Apache/cgi-bin/Districts2.map&"
      + "?REQUEST=GetFeatureInfo"
      + "&EXCEPTIONS=application/vnd.ogc.se_xml"
      + "&BBOX=" + map.getExtent().toBBOX()
      + "&X=" + e.xy.x
      + "&Y=" + e.xy.y
      + "&INFO_FORMAT=text/html"
      + "&QUERY_LAYERS=Botswana_Admin_Districts"
      + "&LAYERS=Botswana_Admin_Districts"
      + "&FEATURE_COUNT=5"
      + "&SRS=EPSG:4326"
      + "&STYLES="
      + "&WIDTH=" + map.size.w
      + "&HEIGHT=" + map.size.h;
    window.open(url,
      "GetFeatureInfo",
      "location=0,status=0,scrollbars=1,width=600,height=150"
</script>
</head>
<body onload="init()">
<h2>OpenLayers Example</h2>
<div id='map'></div>
</body>
</html>
and the mapfile;
MAP
  NAME "Districts2"
  # Map image size
  SIZE 400 400
  UNITS dd
  EXTENT 15.807570 -27.131403 33.564789 -17.550001
  SHAPEPATH 'C:\ms4w\PSI_Shapefiles\'
  #FONTSET './fonts/fonts.txt'
  SYMBOLSET 'C:\ms4w\Apache\cgi-bin\Symbols.sym'
  PROJECTION
    'proj=longlat'
    'ellps=WGS84'
    'datum=WGS84'
    'no_defs'
  END
  # Background color for the map canvas -- change as desired
  IMAGECOLOR 255 255 255
  IMAGEQUALITY 95
  IMAGETYPE agg
  OUTPUTFORMAT
    NAME agg
    DRIVER AGG/PNG
    IMAGEMODE RGB
  END
  # Legend
  LEGEND
    STATUS ON
    KEYSIZE 18 12
    LABEL
      TYPE BITMAP
      SIZE MEDIUM
      COLOR 0 0 89
    END
  END
  # Web interface definition. Only the template parameter
  # is required to display a map. See MapServer documentation
  WEB
    # Set IMAGEPATH to the path where MapServer should
    # write its output.
    IMAGEPATH 'C:\ms4w\tmp\'
    # Set IMAGEURL to the url that points to IMAGEPATH
    # as defined in your web server configuration
    IMAGEURL '\tmp\'
    # WMS server settings
    METADATA
      wms_title           'QGIS-MAP'
      wms_onlineresource
      wms_srs             'EPSG:4326'
	  wms_server_version '1.1.1'
      wms_feature_info_mime_type 'text/html'
    END
    #Scale range at which web interface will operate
    # Template and header/footer settings
    # Only the template parameter is required to display a map. See
    HEADER 'http://localhost/Header.html'
	TEMPLATE 'http://localhost/Body.html'
    FOOTER 'http://localhost/Footer.html'
	END
  LAYER
    NAME 'Botswana_Admin_Districts'
    TYPE POLYGON
	TOLERANCE 10
	TOLERANCEUNITS pixels
    DUMP true
    DATA Botswana_Admin_Districts
    METADATA
      wms_title 'Botswana_Admin_Districts'
	  wms_srs             'EPSG:4326'
      gml_include_items   'NAME'
      wms_include_items   'NAME'
      wms_name  'Botswana_Admin_Districts'
	  gml_featureid 'OBJECTID'
    END
    STATUS ON
    TRANSPARENCY 100
    PROJECTION
    'proj=longlat'
    'ellps=WGS84'
    'datum=WGS84'
    'no_defs'
    END
 CLASS
      OUTLINECOLOR "#C60F0F"
      COLOR 50 50 50
    END
  END
END
The template files;
The header,
<!-- MapServer Template -->
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN"
       "http://www.w3.org/TR/html4/transitional.dtd">
<html>
  <head>
  <!-- enforce the client to display result html as UTF-8 encoding -->
  <meta http-equiv="content-type" content="text/html; charset=UTF-8"></meta>
    <title>GetFeatureInfo example</title>
  </head>
<body>
<table>
<tr>
<th>Name:</th>
</tr>
The body template file;
<tr>
<td>[NAME]</td>
</tr>
and the Footer template file;
</table>
</body>
</html>
View this message in context: http://osgeo-org.1803224.n2.nabble.com/GetFeatureInfo-returns-attribute-name-only-Mapserver-Openlayers-tp5092982p5092982.html
