[OpenLayers-Users] getLonLatFromPixel in IE
Frank Broniewski
brfr at metrico.lu
Tue May 25 09:44:27 EDT 2010
well obviously you can't pass any arguments to an event function (in
IE). The function only has access to window.event. You can do
function coords(event) {
var xy = event.object.getLonLatFromViewPortPx(event.xy);
var x = xy.lon;
var y = xy.lat;
if you enable the console in IE8, you can do inside the event function:
console.log(event) to see what you get
Frank
Am 25.05.2010 15:17, schrieb Luís de Sousa:
> Hi Frank,
> Thank you for your help, but the problem isn't registering the listener,
> but the argument IE is passing to it. The object with which the
> showCoords function is invoked seems to null, so the .xy property
> generates an error.
> Thanks,
> Luís
> On Tue, May 25, 2010 at 12:17 PM, Frank Broniewski <brfr at metrico.lu
> <mailto:brfr at metrico.lu>> wrote:
> Hi,
> I use
> map = new OpenLayers.Map(map_div);
> map.events.register("click", map, showCoords);
> where showCoords the function for display is. Alternatively see
> http://dev.openlayers.org/releases/OpenLayers-2.9.1/examples/events.html
> for an alternate example
> Frank
Frank BRONIEWSKI
METRICO s.à r.l.
géomètres
technologies d'information géographique
rue des Romains 36
L-5433 NIEDERDONVEN
tél.: +352 26 74 94 - 28
fax.: +352 26 74 94 99
http://www.metrico.lu
