[OpenLayers-Users] Layer Switcher Outside of Map Window
Marjie Anderson marjiea1 at gmail.com
Tue May 25 14:10:53 EDT 2010
If I understand what you want correctly, this is shown in the examples.
I used it in my project (demo here):  http://marjie.info/map/
In the javascript, after initialiazing your map:
map.addControl(new OpenLayers.Control.LayerSwitcher(
                { 'div': OpenLayers.Util.getElement('right') }));
In the html:
<div id="right" class="olControlLayerSwitcher"></div>
You will probably want to override the ControlLayerSwitcher style in your CSS as well.
-          Marjie
From: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] On Behalf Of Tonton
Sent: Tuesday, May 25, 2010 6:26 AM
To: users at openlayers.org
Subject: [OpenLayers-Users] [openlayers users]
hello
i would like to have a layers switcher in external of the map box.
is it possible to use OL for or is it necessary to use a other JS library with
i thing about something like that
</script>
 function valider()
{  var valeur = document.choisir.nomdeCouche;
    for (var i=1;i < valeur.length; i++)
    {    if ( valeur[i].checked )
        {   map.layerContainerDiv.children([valeur[i].value].setvisible=true);
    }   else {map.layerContainerDiv.children([valeur[i].value]).setvisible=false;}
}</script>
 <FORM form id='choisir' name='choisir' method=get action="javascript:void(0);" onSubmit="valider(); return false;">
<input id="wms1" name="nomdeCouche" type="checkbox"  value="wms1"><br>
<input id="wms2" name="nomdeCouche" type="checkbox" value="wms2"><br>
<input id="wms3" name="nomdeCouche" type="checkbox" value="wms3"><br>
<input id="wms4" name="nomdeCouche" type="checkbox" value="wms4"><br>
<input type="submit" value="ajouter" >
                        </FORM>
thanks for your comments
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100525/4dc823c0/attachment.html
