[OpenLayers-Users] display different popup for different layer
Giuseppe Naponiello beppenapo at gmail.com
Thu May 27 03:20:57 EDT 2010
Mmhh, I've tried but it's doesn't work, I think because the layer's
attributes are different and I cannot define the same popup content.
I've risolved writing a second function:
function onFeatureSelect(event) {
       feature = event.feature;
       popup = new OpenLayers.Popup.FramedCloud("chicken",
                  feature.geometry.getBounds().getCenterLonLat(),
                  null,
                  "<div><b>Nome:</b> <a href=\"scheda_comune.php?comune=" +
feature.attributes.NOME + "\" target=\"eastFrame\"
onClick=\"outerLayout.open('east')\">" + feature.attributes.NOME
+"</a></div>",
                  null, true, onPopupClose);
       feature.popup = popup;
       map.addPopup(popup);
and
function onFeatureSelect2(event) {
                  null,
                  "<h2>" + feature.attributes.title + "</h2>" +
feature.attributes.description,
toscana.events.on({
                "featureselected": onFeatureSelect,
                "featureunselected": onFeatureUnselect
   poi.events.on({
       "featureselected": onFeatureSelect2,
       "featureunselected": onFeatureUnselect2
...maybe I could write better code but ... it works!!!
thanks
-beppe-
2010/5/25 Alessandro Pasotti <ale.pas at tiscali.it>
> In data lunedì 24 maggio 2010 15:14:54, Giuseppe Naponiello ha scritto:
> : > Hi all,
> > in my project I've 2 layers (layer1, layer2) with different attributes.
> > Layer 1 is in gml format, layer2 is a txt file
> > When I click on the layer1, I open a popup with this code:
> > function onPopupClose(evt) {selectControl.unselect(feature);}
> > //al click su un elemento, creo e visualizzo al popup
> >                   null,
> > +"</a></div>",
> > function onFeatureUnselect(event) {
> >        if (feature.popup){
> >            map.removePopup(feature.popup);
> >            feature.popup.destroy();
> >            feature.popup = null;
> > selectControl = new OpenLayers.Control.SelectFeature(layer1);
> >    //{onSelect: onFeatureSelect, onUnselect: onFeatureUnselect});
> >     layer1.events.on({
> > Now I'd like to display the same kind of popup for the layer2 but I don't
> > know what is the correct code to write!!!
> > thanks
> Hi,
> I think that passing both layers to the select control should work:
> selectControl = new OpenLayers.Control.SelectFeature([layer1, layer2]);
> selectControl.events.register("featureselected", map, onFeatureSelect);
> selectControl.events.register("featureunselected", map, onFeatureUnselect);
> map.addControl(selectControl);
> selectControl.activate();
> Alessandro Pasotti
> itOpen - "Open Solutions for the Net Age"
> w3:  www.itopen.it
> Linux User# 167502
-beppe-
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100527/565233b7/attachment.html
