[OpenLayers-Users] Rules, Styles and context
Andreas Hocevar ahocevar at opengeo.org
Thu May 27 05:35:58 EDT 2010
you are using the context in an incorrect way. Try something like
var context = {
    color: function(feature) {
        return feature.stylers.color;
If you have your color in feature.attributes, you don't need a context at all.
Regards,
Andreas.
On May 27, 2010, at 08:49 , James.Sewell at lisasoft.com wrote:
> Hello,
> I want to dynamically set a strokeColor based on feature.styler.color rather that feature.attribute.color.
> I am using this code:
> var context = function(feature) {
>                 feature.stylers ? ret = feature.stylers : ret = feature.attributes;
>                 ret ? null : ret = feature;
>                 return ret;
> var defaultStyle = new OpenLayers.Style(OpenLayers.Util.applyDefaults({ strokeColor: "${color}", strokeWidth: 3 }
>         , OpenLayers.Feature.Vector.style["default"]), {context: context});
> I have also tried this:
>         , OpenLayers.Feature.Vector.style["default"]), {context: {styler: null}}) ;
> But neither seem to work! I am particularly confused as the top example works for OpenLayers.Rule context manipulation.
> Any hints?
> Cheers,
> James Sewell
> LISAsoft Developer
> +61 (3) 8680 3200 / +61 414 688 892
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
