[OpenLayers-Users] OL and android
Dipl. Inf. Carsten Eider eider at fh-bingen.de
Fri May 28 11:03:49 EDT 2010
Maybe you should have a look at http://www.opentouchmap.org/
Am 28.05.2010 14:46, schrieb christopher.schmidt at nokia.com:
> On May 28, 2010, at 8:40 AM, ext Jimmy Aumard wrote:
>> Hello,
>> I have test OpenLayers example on android and they works but I can't move on map with touch, it's normal? I have no interaction with map
> Android (and most touch browsers) do not support/implement mousemove events based on dragging in the map. There has been some work towards improved touch-based navigation for iPhone using Apple-generated touch events. Assuming the android browser implements similar properties, this effort could also help on Android.
> Regards,
Mit freundlichen Grüßen / Yours faithfully
Carsten Eider
Dipl. Inf. (FH)
Kompetenzzentrum für Innovative Informationssysteme
c/o Fachhochschule Bingen / University of applied sciences Bingen
Berlinstraße 109
55411 Bingen
Tel: +49 (0) 6721 / 409-179
Fax: +49 (0) 6721 / 994-251
email: eider at fh-bingen.de
Internet: iis.fh-bingen.de
Diese E-Mail, inklusive anhängender Dateien, kann vertrauliche und/oder rechtlich geschützte Inhalte enthalten.
Wenn Sie nicht der richtige Adressat sind und diese E-Mail irrtümlich erhalten haben, benachrichtigen Sie bitte sofort den Absender und vernichten Sie sodann die Originalnachricht.
Die unbefugte Kopie, Weiterleitung oder sonstige Verbreitung dieser Nachricht ist nicht gestattet.
This e-mail, including attachments, may contain confidential and/or privileged information.
If you are not the intended recipient, please notify the sender immediately then delete the original message.
Any copying forwarding and/or distribution without permission of the sender is forbidden.
Type: text/x-vcard
Desc: not available
Url : http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100528/1e8c3cbc/eider.vcf
