[OpenLayers-Users] Re: FramedPopup + Broken
Mike Leahy mgleahy at alumni.uwaterloo.ca
Mon Apr 4 12:10:42 EDT 2011
Hi Ricardo,
I had this exact same problem a few months ago.  In my case, the issue was
that the image used as the background for the framed cloud bubble was the
wrong version.  I believe the correct version of the image 'cloud-popup-
relative.png' is located in the root 'img' folder of the openlayers
package...but I had been using my own image directory using a copy of the
image files that sit in 'themes/default/img'.  Once I replaced the file
corresponding file, everything looked fine.
So, maybe try and see if replacing that file solves your problem.
Regards,
Mike
On April 4, 2011 11:27:24 Ricardo Bayley wrote:
> Here goes again, sorry
> 2011/4/4 Ricardo Bayley <ricardo.bayley at gmail.com>
> > Here is a screenshot of what is happening.
> > Does anyone know why is this happening ?
> > Best regards,
> > Ricardo
> >> I am using the onSelect, onUnSelect. In fact Popup does "pop".
> >> But the problem is that the popup is not displaying as it should.
> >> Any ideas ?
> >> 2011/4/3 dr <rykovd at gmail.com>
> >>> If you use SelectFeature control then you should use onSelect and
> >>> onUnselect
> >>> methods instead onFeatureSelect and onFeatureUnelect.
> >>> View this message in context:
> >>> http://osgeo-org.1803224.n2.nabble.com/FramedPopup-Broken-tp6221085p623
> >>> 4709.html Sent from the OpenLayers Users mailing list archive at
> >>> Nabble.com. _______________________________________________
> >>> Users mailing list
> >>> Users at lists.osgeo.org
> >>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20110404/d8ed1167/attachment.html
