AW: [OpenLayers-Users] How can I *set* a point on the
Input-Mapvia JS
pgr1973
pgr1973 at gmx.de
Sun Apr 10 10:29:27 EDT 2011
After quite some trial&error I got a solution (working with the openlayers
module for Drupal and Drupal6):
// lebende OpenLayers Karte aus dem jQuery.data Teil holen
var jdol = $('#openlayers-cck-widget-map-field_gp').data('openlayers');
// Kartenzentrum auf eingegeben Werte und Zoomstufe 15 setzen
jdol.openlayers.setCenter(new OpenLayers.LonLat(lonIn,
latIn).transform(jdol.openlayers.displayProjection,
jdol.openlayers.projection), 15);
// Feature aus den eingegebenen Werten bauen und auf den Featurelayer
hinzufügen
var inputFeature = new OpenLayers.Feature.Vector(new
OpenLayers.Geometry.Point(lonIn.toFixed(12),
latIn.toFixed(12)).transform(jdol.openlayers.displayProjection,
jdol.openlayers.projection));
var featuresLayer = jdol.openlayers.layers[3];
featuresLayer.addFeatures(inputFeature);
The inserts an input point on the input-map at the positions latIn/lonIn
(values taken from the input-form, the user has entered).
'#openlayers-cck-widget-map-field_gp' is dependent on the content-type one
has created inside drupal (has another id with different content-type and
different field-name) and 'layers[3]' from 'jdol.openlayers.layers[3]' is
the layer with the drupalID 'openlayers_drawfeatures_layer' but I couldn't
get it via the drupalID, so I chose the absolute way. Which may be different
depending on the configuration of the input-map of the drupal
openlayers-module.
Regards Paddy
View this message in context: http://osgeo-org.1803224.n2.nabble.com/How-can-I-set-a-point-on-the-Input-Map-via-JS-tp6251457p6258814.html
