[OpenLayers-Users] Re: set start and end point
Sush Pokharel pokharelsush at yahoo.com
Tue Aug 16 15:16:11 EDT 2011
Thanks guys,
yes i am now done with the start and end layer for pgrouting next i wanted to start
php for routing purpose to get the shortest_path route layer.
But i have some confusion simply installing PHP works for the database connection
or have to configure it to work with openlayer?
Regs,
Sushma
To: "openlayers-users at lists.osgeo.org" <openlayers-users at lists.osgeo.org>
Sent: Tuesday, 16 August 2011, 17:04
Subject: set start and end point
Hi Guys,
I am using pgrouting + openlayers
I am trying to set start and end point layer to pass to pgrouting. I tried the code from
http://www.pgrouting.org/docs/ol-workshop/ch05.html. But i couldnot get the layer for start and end point. here is my code:
<html xmlns="http://www.w3.org/1999/xhtml" >
<head>
<style type="text/css" >
#map {
width: 500px;
height: 500px;
border: 1px solid black;
</style>
<script src="openlayers/OpenLayers.js" ></script>
<script type="text/javascript" >
var SinglePoint = OpenLayers.Class.create();
 SinglePoint.prototype = OpenLayers.Class.inherit(OpenLayers.Handler.Point, {
     createFeature: function(evt)
         this.control.layer.removeFeatures(this.control.layer.features);
         OpenLayers.Handler.Point.prototype.createFeature.apply(this, arguments);
 var start_style = OpenLayers.Util.applyDefaults({
                externalGraphic: "start.png",
                graphicWidth: 18,
                graphicHeight: 26,
                graphicYOffset: -26,
                graphicOpacity:
 1
            }, OpenLayers.Feature.Vector.style['default']);
            var stop_style = OpenLayers.Util.applyDefaults({
                externalGraphic: "stop.png",
                graphicWidth: 18,
                graphicHeight: 26,
                graphicOpacity: 1
var map;
var dublin;
var counties;
var start;
var stop;
function init() {
               var bounds = new OpenLayers.Bounds(
                    297730.375, 217955.328,
                    330136.625, 260578.453
                var options = {
                    controls: [new OpenLayers.Control.PanZoom()
                    maxExtent: bounds,
                    maxResolution: 166.49658203125,
                    projection: "EPSG:29900",
                    units: 'm'
                map = new OpenLayers.Map('map', options);
dublin = new OpenLayers.Layer.WMS( "dublin historical"
"http://localhost:8080/geoserver/wms?" ,
{layers: 'Ireland:buildings_geodir',transparent:true} );
 counties = new OpenLayers.Layer.WMS( "counties" ,
{layers: 'Ireland:dublin_highway1'} );
start = new OpenLayers.Layer.Vector("Start point", {style: start_style});
stop = new OpenLayers.Layer.Vector("End point", {style: stop_style});
map.addLayer(counties);
map.addLayer(dublin);
map.addLayer(start);
map.addLayer(stop);
                map.addControl(new OpenLayers.Control.Navigation());
                map.addControl(new OpenLayers.Control.LayerSwitcher()
                map.addControl(new OpenLayers.Control.MousePosition({element: $('location')}));
                map.zoomToExtent(bounds);
 controls = {
   start: new OpenLayers.Control.DrawFeature(start, SinglePoint),
      stop: new OpenLayers.Control.DrawFeature(stop, SinglePoint)
    for (var key in controls) {
        map.addControl(controls[key]);
function toggleControl(element) {
    for (key in controls) {
        if (element.value == key && element.checked)
            controls[key].activate();
        } else {
            controls[key].deactivate();
</script>
</head>
<body onload="init()" >
<div id="map" ></div>
<li>
        <input type="radio" name="control" value="start" id="startToggle"
                   onclick="toggleControl(this);" />
        <label for="startToggle">set start
 point</label>
</li>
 <li>
            <label for="startToggle">set start point</label>
          </li>
</body>
</html>
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20110816/4e13db26/attachment.html
