[OpenLayers-Users] measure immediate problem
tvnc tvnc1979 at gmail.com
Wed Aug 17 06:08:48 EDT 2011
i want to show measured distance on mouse move, but can't get to work. maybe
someone can see mistake
            var bot = new OpenLayers.Control.Button({
    				displayClass: 'olIkonaUdalj',
    				eventListeners: {
				  	'activate': klikLivo,
				  	'deactivate': brisMarkera},
				  	type: 2
					var kontr = new OpenLayers.Control.Panel
					 div: document.getElementById("bp"),
				    //defaultControl: bot
				kontr.addControls([bot]);
            map.addControl(kontr);
function klikLivo(event) {
var crta = new OpenLayers.Control.Measure(OpenLayers.Handler.Path, {persist:
true, immediate: true});
                crta.events.on({
                    "measure": handleMeasurements,
                    "measurepartial": handleMeasurements
                map.addControl(crta);
                crta.activate();
function handleMeasurements(event) {
            var geometry = event.geometry;
            var units = event.units;
            var order = event.order;
            var measure = event.measure;
            var element = document.getElementById('au');
            var out = "";
            if(order == 1) {
                out += "measure: " + measure.toFixed(3) + " " + units;
            } else {
                out += "measure: " + measure.toFixed(3) + " " + units +
"<sup>2</" + "sup>";
            element.innerHTML = out;
function brisMarkera(){alert("Brišemo markere");}
