[OpenLayers-Users] Formatting output text
    JK Chen
    jk.chen at sdl.usu.edu
    Thu Aug 18 15:11:53 EDT 2011
Ya, I did that, but didn't work for me.  Here is my code,
  <script type='text/javascript' src='js/OpenLayers.js'></script>
  <script type="text/javascript">
  OpenLayers.LonLat.prototype.toString = function()
    if (this.lat < 0)
      var ns = "S";
      this.lat = Math.abs(this.lat);
    else
      var ns = "N";
    if (this.lon < 0)
      var ew = "W";
      this.lon = Math.abs(this.lon);
    else
      var ew = "E";
    return (ns + "  " + this.lat.toFixed() + ", " + ew + " " + this.lon.toFixed());
  </script>
-----Original Message-----
From: Bart van den Eijnden (OSGIS) [mailto:bartvde at osgis.nl]
Sent: Thursday, August 18, 2011 12:06 AM
To: JK Chen
Cc: Bart van den Eijnden; Joel Leininger; openlayers-users at lists.osgeo.org
Subject: RE: [OpenLayers-Users] Formatting output text
In a script tag after the OpenLayers.js script tag, e.g.
<script type="text/javascript" src="OpenLayers.js"></script> <script type="text/javascript"> // code goes here </script>
Best regards,
Bart
> Where should the new code be inserted to?
> Thanks.
> JK
> From: openlayers-users-bounces at lists.osgeo.org
> [mailto:openlayers-users-bounces at lists.osgeo.org] On Behalf Of Bart
> van den Eijnden
> Sent: Tuesday, August 16, 2011 11:28 AM
> To: Joel Leininger
> Cc: openlayers-users at lists.osgeo.org
> Subject: Re: [OpenLayers-Users] Formatting output text
> You could override the toString method of LonLat:
> OpenLayers.LonLat.prototype.toString = function() {
>     return ("N " + this.lat.toFixed() + ", E " + this.lon.toFixed());
> Best regards,
> Bart
> OSGIS - http://osgis.nl<http://opengeo.org/>
> On Aug 16, 2011, at 7:21 PM, Joel Leininger wrote:
> How do I go about reformatting the text output from a coordinate
> variable?
> In other words, I have output from a mouse position which has been
> transformed into different coordinate systems, and then gets displayed
> on the screen.
> It now looks something like this:
> lon=414614.58552010887,lat=164066.82345258445
> In reality, the values are x and y coords in feet or meters, not
> lonlat coords. I'd like them to look like this:
> N 164066, E 414614
> Note the truncation of the digits and switching of the x, y (which is
> customary in my field). Not being a JS expert, I can't figure out how
> to get at the variable to massage the format prior to display on the
> screen.
> Here's the code leading up to the display (inside of a mousemove
> function):
> mousepos = map.getLonLatFromViewPortPx(e);
> var NAD83ft_values = mousepos.clone();   // done several times for
> different coord translations
> NAD83ft_values.transform(WGS84_google_mercator, NAD83ft_proj);
> document.getElementById("NAD83feet").innerHTML = NAD83ft_values;
> It's unpacking NAD83ft_values that has me thrown. Any help?
> -J.
> Users mailing list
> Users at lists.osgeo.org<mailto:Users at lists.osgeo.org>
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
