[OpenLayers-Users] Re: WFS via Geoserver
killerz eoinskilleen at gmail.com
Fri Aug 19 11:51:30 EDT 2011
Hi
You do not need a proxy for localhost.
Your error is probably is to do with the featureNS. In geoserver go to
workspaces, click on whichever one you have stored your data in, the
Namespace URI is what you need to put for featureNS.
For example if your data is stored in topp your featureNS wil be:
http://www.openplans.org/topp
If you create your own workspace you enter the Namespace URI into geoserver.
You can enter anything such as http://test.com and as long as you enter the
same value in openlayers it will work fine. This is for sure with localhost
I haven’t hosted online.
Good luck!
View this message in context: http://osgeo-org.1803224.n2.nabble.com/WFS-via-Geoserver-tp6703325p6703782.html
