[OpenLayers-Users] Re: measure segment length
tvnc tvnc1979 at gmail.com
Fri Aug 19 14:34:36 EDT 2011
tvnc <tvnc1979 at ...> writes:
> how could i using measure control (immediat set to true) get measure segments
> length set in array so i can grab and show each one
i get it work with setImmediate set to false, but i want to store all measure
segment lenght in array with setImmediate set to true
crta = new OpenLayers.Control.Measure(OpenLayers.Handler.Path,
                               {persist: true, geodesic: true});
crta.events.on({
     "measure": handleFinalMeasurement,
     "measurepartial": handlePartialMeasurement
                map.addControl(crta);
                crta.activate();
                crta.setImmediate(true);
unction handleFinalMeasurement(event) {
    var units = event.units;
    		var geometry = event.geometry;
    var measure = event.measure;
     var element = document.getElementById('au');
     var br = tocke[1].components.length;
    var out = "udaljenost: " + (measure*0.5399).toFixed(2) + "  NM";
        out += "    zadnji segment: " + duz.toFixed(2) + "  NM";
    element.innerHTML = out;
var zd =[];
function handlePartialMeasurement(event) {
		tocke.length = 0;
		var geo = geometry.clone().transform(new OpenLayers.Projection
("EPSG:900913"), new OpenLayers.Projection("EPSG:4326"));
		tocke.push(geo);
		var bt = tocke.length;
		var br = tocke[bt-1].components.length;
		var od = tocke[bt-1].components[br-2];
		var ddo = tocke[bt-1].components[br-1];
		var ls = new OpenLayers.Geometry.LineString([od, ddo]);
		duz = ls.getGeodesicLength()*0.5399/1000;
zd.push(duz);
