[OpenLayers-Users] getfeatureinfo mapserver show only the atributname
Jean-François Gigand jf at geonef.fr
Tue Aug 23 09:18:11 EDT 2011
- In your mapfile,  try setting "ows_enable_request" to "*".
- instead of "postgis:Batas_Kab_region", I guess you should just
specify "Batas_Kab_region"
- you should add EPSG:900913 to the list of wms_srs
- there is a control in OpenLayers that do the job :
OpenLayers.Control.WMSGetFeatureInfo
  It would be interesting for you to use it.
- try settings a log file for MapServer, you may have some useful
information there
If you still have the problem, can you give what is returned by the server?
Jean-François Gigand - Geonef
Paris, France - http://geonef.fr/
2011/8/22 Arnd Wippermann <arnd.wippermann at web.de>:
> Hi,
> In your body template you need for every field, you want to show, an entry:
> <tr><td>Field1</td><td>[Field1]</td></tr>
> <tr><td>Field2</td><td>[Field2]</td></tr>
> <tr><td>Field3</td><td>[Field3]</td></tr>
> Arnd
> -----Ursprüngliche Nachricht-----
> Von: openlayers-users-bounces at lists.osgeo.org
> [mailto:openlayers-users-bounces at lists.osgeo.org] Im Auftrag von boho
> Gesendet: Montag, 22. August 2011 19:12
> An: users at openlayers.org
> Betreff: [OpenLayers-Users] getfeatureinfo mapserver show only the
> atributname
> is there anything that can help me display the data from. dbf with
> OpenLayers getfeatureinfo function ..
> I've tried it but it appeared only the name attribute This is my OpenLayers
> code:
> <script type="text/javascript">
>        function init(){
>                var lon = 99.09668;
>                                var lat = 2.890000;
>                                var zoom = 12;
>                var map = new OpenLayers.Map('map');
>                var layer = new
> OpenLayers.Layer.WMS('Batas_Kab_region','http://localhost/cgi-bin/mapserv.ex
> e?map=C:/ms4w/Apache/htdocs/cobaLabel/batasKab.map&;',{layers:'Batas_Kab_reg
> ion'});
>                var bank = new
> OpenLayers.Layer.WMS('BANK','http://localhost/cgi-bin/mapserv.exe?map=C:/ms4
> w/Apache/htdocs/cobaLabel/batasKab.map&;',{layers:'BANK'});
>                map.addLayer(layer,bank);
>                map.setCenter(new OpenLayers.LonLat(lon, lat), zoom);
>                map.events.register('click', map, function (e) {
>    var url =
> 'http://localhost/cgi-bin/mapserv.exe?map=C:/ms4w/Apache/htdocs/cobaLabel/ba
> tasKab.map&'
>      + "?REQUEST=GetFeatureInfo"
>      + "&EXCEPTIONS=application/vnd.ogc.se_xml"
>      + "&BBOX=" + map.getExtent().toBBOX()
>      + "&X=" + e.xy.x
>      + "&Y=" + e.xy.y
>      + "&INFO_FORMAT=text/html"
>      + "&QUERY_LAYERS=Batas_Kab_region"
>      + "&LAYERS=postgis:Batas_Kab_region"
>      + "&FEATURE_COUNT=50"
>      + "&SRS=EPSG:900913"
>      + "&STYLES="
>      + "&WIDTH=" + map.size.w
>      + "&HEIGHT=" + map.size.h;
>    window.open(url,
>      "getfeatureinfo",
>      "location=0,status=0,scrollbars=1,width=600,height=150"
> this my mapfile :
> # Map file created from QGIS project file C:/Program Files/Quantum GIS
> Enceladus/as'.qgs # Edit this file to customize for your map interface #
> (Created with PyQgis MapServer Export plugin) MAP
>  NAME "QGIS-MAP"
>  # Map image size
>  SIZE 400 200
>  UNITS meters
>    EXTENT 96.802857 1.212928 102.390585 3.803407
>  FONTSET './fonts/fonts.txt'
>  SYMBOLSET './symbols/symbols.sym'
>  PROJECTION
>    'proj=longlat'
>    'ellps=WGS84'
>    'datum=WGS84'
>    'no_defs'
>  END
>  # Background color for the map canvas -- change as desired
>  IMAGECOLOR 255 255 255
>  IMAGEQUALITY 95
>  IMAGETYPE png
>  OUTPUTFORMAT
>    NAME png
>    DRIVER 'GD/PNG'
>    MIMETYPE 'image/png'
>    IMAGEMODE RGBA
>    EXTENSION 'png'
>  END
>  # Legend
>  LEGEND
>    STATUS ON
>    KEYSIZE 18 12
>    LABEL
>      TYPE BITMAP
>      SIZE MEDIUM
>      COLOR 0 0 89
>    END
>  END
>  # Web interface definition. Only the template parameter
>  # is required to display a map. See MapServer documentation
>  WEB
>    # Set IMAGEPATH to the path where MapServer should
>    # write its output.
>    IMAGEPATH 'C:\ms4w\Apache\htdocs\cobaLabel\tmp\'
>    # Set IMAGEURL to the url that points to IMAGEPATH
>    # as defined in your web server configuration
>    IMAGEURL 'C:\ms4w\Apache\htdocs\cobaLabel\tmp\'
>    # WMS server settings
>    METADATA
>      'wms_title'           'QGIS-MAP'
>      'wms_onlineresource'
> 'http:/localhost/cgi-bin/mapserv.exe?map=C:/ms4w/Apache/htdocs/cobaLabel/bat
> asKab.map'
>      "wms_srs"   "EPSG:42304 EPSG:42101 EPSG:4269 EPSG:4326"
>        "wms_abstract"      "This demonstration server was setup by DM
> Solutions
> Group (http://www.dmsolutions.ca/) and is powered by the UMN MapServer
> (http://mapserver.gis.umn.edu/).  This server uses Canadian source data
> (c)2000, Government of Canada with permission from Natural Resources Canada
> from NRCan's GeoGratis web site (http://geogratis.cgdi.gc.ca/)."
> "wms_feature_info_mime_type" "text/html"
> 'wms_include_items'  'all'
>    END
>    #Scale range at which web interface will operate
>    # Template and header/footer settings
>    # Only the template parameter is required to display a map. See
>    TEMPLATE 'http://localhost/cobaLabel/template/template.html'
>  END
>  LAYER
>    NAME 'Batas_Kab_region'
>    TYPE POLYGON
>    DUMP true
>        LABELITEM "KECAMATAN"
>    DATA 'C:/ms4w/Apache/htdocs/siantar/Batas_Kab_region.shp|layerid=0'
>    METADATA
>      'wms_title' 'Batas_Kab_region'
>     "wms_dataurl_format" "text/HTML"
>    "gml_include_items"     "all"
>    "gml_exclude_items"     ""
>    "ows_include_items"     "all"
>    "ows_exclude_items"     ""
>    "wms_exceptions_format" "application/vnd.ogc.se_xml"
>  'wms_srs'             'EPSG:4326'
>    END
>    STATUS ON
>    TRANSPARENCY 100
>    PROJECTION
>    'proj=longlat'
>    'ellps=WGS84'
>    'datum=WGS84'
>    'no_defs'
>    END
>    CLASS
>       STYLE
>         SYMBOL 0
>         SIZE 7.0
>         OUTLINECOLOR 0 0 0
>         COLOR 78 109 18
>       END
>     LABEL
>      FONT vera
>      TYPE truetype
>      SIZE 12
>      COLOR 0 0 0
>      ANGLE 0
>      BUFFER 1
>      POSITION cc
>      FORCE true
>      ANTIALIAS true
>      PARTIALS true
>     END
>    END
>  END
> END
> and this my template web :
> &lt;!DOCTYPE HTML PUBLIC &quot;-//W3C//DTD HTML 4.01 Transitional//EN&quot;
>       &quot;http://www.w3.org/TR/html4/transitional.dtd&quot;;&gt;
> <html>
>  <head>
>  <meta http-equiv="content-type" content="text/html; charset=UTF-8"></meta>
>    <title>GetFeatureInfo example</title>
>  </head>
> <body>
> <table>
> <tr>
> <th>KECAMATAN:</th>
> </tr>
> The body template file;
> <tr>
> <td>[KECAMATAN]</td>
> </tr>
> and the Footer template file;
> </table>
> </body>
> </html>
> pleasee somebody help me....
> http://osgeo-org.1803224.n2.nabble.com/getfeatureinfo-mapserver-show-only-th
> e-atribut-name-tp6712417p6712417.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
> Users mailing list
