[OpenLayers-Users] ArcGIS cache jumping around
Bart van den Eijnden bartvde at osgis.nl
Tue Aug 23 14:41:14 EDT 2011
is your server publicly available? Are you able to create a reproducible minimal example?
Or can you at least provide the JSON config?
Best regards,
Bart
OSGIS - http://osgis.nl
On Aug 18, 2011, at 9:52 PM, osullivj wrote:
> Hi,
> I am trying to bring in some arcgis data in web mercator following the
> example here - http://openlayers.org/dev/examples/arcgiscache_ags.html
> I can get it working ok but the map jumps around when I am zooming and
> panning
> I used the json metadata object similar to the example so it should be
> picking up the correct values for maxextent, resolutions, tileorigin,
> tilesize etc...
> The cache is single fused made up of about 14 layers
> Any ideas on how I might fix this?
> Thanks,
> J
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/ArcGIS-cache-jumping-around-tp6700610p6700610.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20110823/905e07ce/attachment.html
