[OpenLayers-Users] "P is undefined"-Error after builing a singleFile-edition
Eric Lemoine eric.lemoine at camptocamp.com
Sun Aug 28 05:20:58 EDT 2011
On Fri, Aug 26, 2011 at 1:40 PM, Marco Scheuble <mail at marco-scheuble.de> wrote:
> Hi all,
> I extended Openlayers with the Class = OpenLayers.Layer.Wetter4.
> As long as I'm using 'lib/OpenLayers.js' everything works fine.
> But if I take the builded singleFile 'OpenLayers.js' I get the error: "P is
> undefined".
> Anyone can give me a hint?
> Thanks in advance,
> Marco
> OpenLayers.Layer.Wetter4 = OpenLayers.Class(OpenLayers.Layer.TMS, {
>        initialize: function(name, url, options) {
>            OpenLayers.Layer.TMS.prototype.initialize.apply(this, [name,
> url, options]);
>            this.singleTile = true;
>            this.ratio = 1;
>            this.options.setting = '&leg=nil&a=image';
>        getURL: function(bounds) {
>            var x1 = bounds.left;
>            var x2 = bounds.right;
>            var y1 = bounds.bottom;
>            var y2 = bounds.top;
>            var date = (this.options.dt != undefined) ? this.options.dt : '';
>            var q = this.options.query;
>            var setting = this.options.setting;
>            setting += '&x=' + this.tileSize.w + '&y=' + this.tileSize.h;
>            var src = this.url + 'q=' + q + setting + '&x1=' + x1 + '&x2=' + x2 +
> '&y1=' + y1 + '&y2=' + y2 + '&dt=' + date;
>            return src;
>        CLASS_NAME: 'OpenLayers.Layer.Wetter4'
You have to have Layer/TMS.js in the built OpenLayers.js script. And
you need to make sure the browser evaluates OpenLayers.js before your
own script.
Cheers,
Eric Lemoine
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel : 00 33 4 79 44 44 96
Mail : eric.lemoine at camptocamp.com
http://www.camptocamp.com
