[OpenLayers-Users] how to change the size of OpenLayers.Layer.Image
JK Chen jk.chen at sdl.usu.edu
Mon Aug 29 10:00:20 EDT 2011
Very good. Thanks.
BTW, the example says the size value has no effect. Perfect for me.
Regards.
-----Original Message-----
From: arnd.wippermann at web.de [mailto:arnd.wippermann at web.de]
Sent: Thursday, August 25, 2011 12:38 PM
To: JK Chen
Cc: users at openlayers.org
Subject: AW: [OpenLayers-Users] how to change the size of OpenLayers.Layer.Image
You have to know the width and height in map units and the insert point for your image.
Say x0,y0 und w,h im map units, then
imgLayer.extent=new OpenLayers.Bounds(x0,y0,x0+w,y0+h);
Here you can see, how it works:
http://gis.ibbeck.de/OLClient/examples/ArcGIS93Rest.html
Regards,
Arnd
-----Ursprüngliche Nachricht-----
Von: JK Chen [mailto:jk.chen at sdl.usu.edu]
Gesendet: Donnerstag, 25. August 2011 16:23
An: arnd.wippermann at web.de
Betreff: RE: [OpenLayers-Users] how to change the size of OpenLayers.Layer.Image
Suppose my image is w and h, how I code? Into extent? Why?
Sent: Wednesday, August 24, 2011 6:20 PM
To: JK Chen
Try to set a new extent for the layer:
imgLayer.extent=new OpenLayers.Bounds(-70,-10,70,10);
This is perhaps needed to refresh the layer imgLayer.setVisibility(false); imgLayer.setVisibility(true);
Arnd
Von: openlayers-users-bounces at lists.osgeo.org
[mailto:openlayers-users-bounces at lists.osgeo.org] Im Auftrag von jk
Gesendet: Mittwoch, 24. August 2011 21:27
An: users at openlayers.org
Betreff: [OpenLayers-Users] how to change the size of OpenLayers.Layer.Image
I am trying to use OL to view military images, jpeg, of various dimensions.
I need to maintain the orginal aspect. Now, how to specify the size values when creating a new Layer.Image?
Is it possible to change those values after image loads?
How?
Thanks.
JK
View this message in context:
http://osgeo-org.1803224.n2.nabble.com/how-to-change-the-size-of-OpenLayers-
Layer-Image-tp6721664p6721664.html
Users mailing list
Users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/openlayers-users
