[OpenLayers-Users] how to change the size of
OpenLayers.Layer.Image
JK Chen
jk.chen at sdl.usu.edu
Tue Aug 30 13:28:04 EDT 2011
Arnd,
Did you mean I can display image right inside polygon? I attached the screenshot here that shows my polygons.
Each of these polygons represents the four corners of sensed images from devices of aircrafts.
Thanks.
JK
-----Original Message-----
From: arnd.wippermann at web.de [mailto:arnd.wippermann at web.de]
Sent: Monday, August 29, 2011 1:21 PM
To: JK Chen
Cc: users at openlayers.org
Subject: AW: [OpenLayers-Users] how to change the size of OpenLayers.Layer.Image
new OpenLayers.Bounds(-118.354,32.834, -118.383, 32.819) should be new OpenLayers.Bounds(left, bottom, right, top)
but
-118.354 > -118.383
32.834 > 32.819
try
new OpenLayers.Bounds(-118.383, 32.819, -118.354,32.834)
Openlayers can't display rotated images as Layer.Image. If you want to display rotated images, you can use as workaround a vector layer with point feature and externalGraphic.
Good Luck
Arnd
-----Ursprüngliche Nachricht-----
Von: JK Chen [mailto:jk.chen at sdl.usu.edu]
Gesendet: Montag, 29. August 2011 18:16
An: arnd.wippermann at web.de; users at openlayers.org
Betreff: RE: [OpenLayers-Users] how to change the size of OpenLayers.Layer.Image
Well, it is not working for me.
My image is not up-right rectangle. Mine are skewed rectangles.
1. The BBOX for OpenLayers.Image does not have a way to specify that, Please, OL folks can you confirm that?
2. If I put in the two values of bottom left and top right, my image will not load.
3. If I specify (-180, -90, 180, 90) for BBox, my image will load. But as you know, it is not correct. In terms of aspect ratio.
Here is my image, it's four corners, and my OL code. My image is NITF military image, I have converted to JPEG listed in this email.
Thanks.
-- ol code --
map = new OpenLayers.Map('map_element', {});
var image_layer = new OpenLayers.Layer.Image(
'Wallpaper',
'http://localhost:8080/198/lynx2003050817522799.ntf.jpg',
//'http://localhost:8080/187/31AUG939Z0000002ZX000013ZZ0000004DB89A19.ntf.jp
g',
//'http://earthtrends.wri.org/images/maps/4_m_citylights_lg.gif',
//new OpenLayers.Bounds(-180,-90,180,90), // this will display the image, but of course it's not right in aspect ratio
new OpenLayers.Bounds(-118.354,32.834, -118.383, 32.819), // these values are "correct", but the image will NOT load
new OpenLayers.Size(0,0),
{numZoomLevels:10, maxResolution:.625}
--- the four corners
Corner Coordinates:
Upper Left (-118.3786921, 32.8152343) (118d22'43.29"W, 32d48'54.84"N) Lower Left (-118.3537928, 32.8343191) (118d21'13.65"W, 32d50'3.55"N) Upper Right (-118.3825927, 32.8188274) (118d22'57.33"W, 32d49'7.78"N) Lower Right (-118.3576934, 32.8379122) (118d21'27.70"W, 32d50'16.48"N)
Center (-118.3681927, 32.8265733) (118d22'5.49"W, 32d49'35.66"N)
--- my image (nitf) display in OpenEV
-- my image file (jpeg)
JK
Sent: Monday, August 29, 2011 8:00 AM
To: 'arnd.wippermann at web.de'
Subject: RE: [OpenLayers-Users] how to change the size of OpenLayers.Layer.Image
Very good. Thanks.
BTW, the example says the size value has no effect. Perfect for me.
Regards.
Sent: Thursday, August 25, 2011 12:38 PM
To: JK Chen
You have to know the width and height in map units and the insert point for your image.
Say x0,y0 und w,h im map units, then
imgLayer.extent=new OpenLayers.Bounds(x0,y0,x0+w,y0+h);
Here you can see, how it works:
http://gis.ibbeck.de/OLClient/examples/ArcGIS93Rest.html
Regards,
Arnd
Gesendet: Donnerstag, 25. August 2011 16:23
Suppose my image is w and h, how I code? Into extent? Why?
Sent: Wednesday, August 24, 2011 6:20 PM
To: JK Chen
Try to set a new extent for the layer:
imgLayer.extent=new OpenLayers.Bounds(-70,-10,70,10);
This is perhaps needed to refresh the layer imgLayer.setVisibility(false); imgLayer.setVisibility(true);
Arnd
Von: openlayers-users-bounces at lists.osgeo.org
[mailto:openlayers-users-bounces at lists.osgeo.org] Im Auftrag von jk
Gesendet: Mittwoch, 24. August 2011 21:27
An: users at openlayers.org
Betreff: [OpenLayers-Users] how to change the size of OpenLayers.Layer.Image
I am trying to use OL to view military images, jpeg, of various dimensions.
I need to maintain the orginal aspect. Now, how to specify the size values when creating a new Layer.Image?
Is it possible to change those values after image loads?
How?
Thanks.
JK
View this message in context:
http://osgeo-org.1803224.n2.nabble.com/how-to-change-the-size-of-OpenLayers-
Layer-Image-tp6721664p6721664.html
Users mailing list
Users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/openlayers-users
Type: image/jpeg
Desc: polygon.jpg
Url : http://lists.osgeo.org/pipermail/openlayers-users/attachments/20110830/e637b5d1/polygon.jpg
