[OpenLayers-Users] Re: openlayers job
dr
rykovd at gmail.com
Wed Feb 16 01:18:22 EST 2011
Hi, janmartin
I've faced with similar problem and get the following explanation :
Andreas Hocevar wrote:
> Because for the SelectFeature control to work, the svg/vml container needs
> to be on top of the layer stack. If you configure it with multiple layers,
> it will create its own container on top of all other layers. If you
> configure it with a single layer, it will move this layer to the top of
> the layer stack.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/openlayers-job-tp6030177p6030659.html
