[OpenLayers-Users] Re: problem with browsers except firefox
Fco. Javier García Ricca
fjricca at gmail.com
Wed Feb 16 09:15:21 EST 2011
Don't worry, I've solved the problem.
2011/2/16 javiricca <fjricca at gmail.com>
> I forgot to put the code:
> <html>
> <head>
> <title>Simple OSM GPX Track</title>
> <!-- bring in the OpenLayers javascript library
> (here we bring it from the remote site, but you could
> easily serve up this javascript yourself) -->
> <script src="http://www.openlayers.org/api/OpenLayers.js"></script>
> <!-- bring in the OpenStreetMap OpenLayers layers.
> Using this hosted file will make sure we are kept up
> to date with any necessary changes -->
> <script
> src="http://www.openstreetmap.org/openlayers/OpenStreetMap.js"></script>
> <style type="text/css">
> @media print {
> div,a {display:none}
> .ver {display:block}
> .nover {display:none}
> .olControlZoomInItemInactive {
> background:url(
> http://dev.openlayers.org/releases/OpenLayers-2.8/img/zoom-plus-mini.png)
> no-repeat;
> border:2px solid #232323;
> float:left;
> height:18px;
> margin-right:5px;
> width:18px;
> .olControlZoomOutItemInactive {
> background:url(
> http://dev.openlayers.org/releases/OpenLayers-2.8/img/zoom-minus-mini.png)
> no-repeat;
> float:left;
> height:18px;
> margin-right:5px;
> width:18px;
> </style>
> <script type="text/javascript">
> // Start position for the map (hardcoded here for
> simplicity,
> // but maybe you want to get this from the URL params)
> var lat=37.364677
> var lon=-4.681113
> var zoom=8
> var map; //complex object of type OpenLayers.Map
> function init() {
> map = new OpenLayers.Map ("map", {
> controls:[
> new OpenLayers.Control.Navigation(),
> <!-- new
> OpenLayers.Control.PanZoomBar(),-->
> new
> OpenLayers.Control.LayerSwitcher(),
> new
> OpenLayers.Control.Attribution()],
> maxResolution: 156543.0399,
> numZoomLevels: 19,
> units: 'm',
> projection: new
> OpenLayers.Projection("EPSG:900913"),
> displayProjection: new
> OpenLayers.Projection("EPSG:4326")
> // Define the map layer
> // Here we use a predefined layer that will be kept
> up to date with URL
> changes
> layerMapnik = new
> OpenLayers.Layer.OSM.Mapnik("Mapnik");
> map.addLayer(layerMapnik);
> layerTilesAtHome = new
> OpenLayers.Layer.OSM.Osmarender("Osmarender");
> map.addLayer(layerTilesAtHome);
> layerCycleMap = new
> OpenLayers.Layer.OSM.CycleMap("CycleMap");
> map.addLayer(layerCycleMap);
> layerMarkers = new
> OpenLayers.Layer.Markers("Markers");
> map.addLayer(layerMarkers);
> // Add the Layer with the GPX Track
> var lgpx = new OpenLayers.Layer.GML("Ruta2",
> "track2.gpx", {
> format: OpenLayers.Format.GPX,
> style: {strokeColor: "green", strokeWidth:
> 4, strokeOpacity: 1},
> projection: new
> map.addLayers([lgpx]);
> map.mapExtent = new
> OpenLayers.Bounds(lgpx.getExtent);
> var lonLat = new OpenLayers.LonLat(lon,
> lat).transform(new
> OpenLayers.Projection("EPSG:4326"), map.getProjectionObject());
> map.setCenter(lonLat, zoom);
> var size = new OpenLayers.Size(21, 25);
> var offset = new OpenLayers.Pixel(-(size.w/2),
> -size.h);
> var icon = new
> OpenLayers.Icon('http://www.openstreetmap.org/openlayers/img/marker.png
> ',size,offset);
> layerMarkers.addMarker(new
> OpenLayers.Marker(lonLat,icon));
> var external_control = new
> OpenLayers.Control.MousePosition({
> div:
> document.getElementById('external_control') });
> map.addControl(external_control);
> var external_panel = new OpenLayers.Control.Panel({
> div:
> document.getElementById('panel') });
> map.addControl(external_panel);
> var control_zoom_in = new
> OpenLayers.Control.ZoomIn();
> var control_zoom_out = new
> OpenLayers.Control.ZoomOut();
> map.addControl(control_zoom_in);
> map.addControl(control_zoom_out);
> external_panel.addControls([control_zoom_in,
> control_zoom_out]);
> select = new OpenLayers.Control.SelectFeature([lgpx]);
> lgpx.events.on({
> "featureselected": onFeatureSelect,
> "featureunselected": onFeatureUnselect
> map.addControl(select);
> select.activate();
> function onPopupClose(evt) {
> select.unselectAll();
> function onFeatureSelect(event) {
> var feature = event.feature;
> // Since KML is user-generated, do naive
> protection against
> // Javascript.
> var content = "<h2>"+
> feature.attributes.name + "</h2>" + <td> track2.gpx
> Descargar track </td>;
> if (content.search("<script") != -1) {
> content = "Content contained
> Javascript! Escaped content below.<br />"
> + content.replace(/</g, "<");
> popup = new
> OpenLayers.Popup.FramedCloud("chicken",
> feature.geometry.getBounds().getCenterLonLat(),
> new OpenLayers.Size(100,100),
> content,
> null, true, onPopupClose);
> feature.popup = popup;
> map.addPopup(popup);
> function onFeatureUnselect(event) {
> if(feature.popup) {
> map.removePopup(feature.popup);
> feature.popup.destroy();
> delete feature.popup;
> </script>
> </head>
> <!-- body.onload is called once the page is loaded (call the 'init'
> function) -->
> <body onload="init();">
> <!-- define a DIV into which the map will appear. Make it take up
> the whole
> window -->
> <div style="width:90%; height:90%" id="map"></div>
> <div id="external_control"></div>
> <div id="panel"></div>
> </body>
> </html>
> http://osgeo-org.1803224.n2.nabble.com/problem-with-browsers-except-firefox-tp6031310p6031478.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
FJRicca
http://picasaweb.google.es/fjricca
http://perdonaqueseasoez.com/
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20110216/03b7960c/attachment-0001.html
