[OpenLayers-Users] How to enlarge Map size
Alexandre Dube
adube at mapgears.com
Fri Feb 25 10:00:18 EST 2011
Look at the "smallmap" class inside the example css file :
http://dev.openlayers.org/releases/OpenLayers-2.10/examples/style.css
You'll see that the map size is determined by its <div> container. You
simply need to define it :
<div id='map' style='width: 800px; height: 800px;'></div>
Alexandre
On 11-02-25 08:56 AM, Mustafa646 wrote:
> <div id= "Map", class= "smallmap">
> by using this code, we can only show small map.
> How to enlarge the Map or how we can set the width and height ?
Alexandre Dubé
Mapgears
www.mapgears.com
