[OpenLayers-Users] Click Handler callback invoked 3 times
Eric Lemoine
eric.lemoine at camptocamp.com
Sun Jul 10 14:20:15 EDT 2011
On Sun, Jul 10, 2011 at 10:13 AM, Dave Potts <dave.potts at pinan.co.uk> wrote:
> Using openlayers 2.10 I have installed a click
> handler(Openlayers.Handler.Click) on a map , using a scale as the
> control argument and the register function to install the callback as
> type click.
> When ever I do a single click, the call back routine gets called 3
> times, is there any reason for this? I had assume it would only be
> called once.
> The same things happens with the double click callback!
> I have checked and the callback is only installed once.
Hi. It is difficult to help you without seeing actual code.
Eric Lemoine
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel : 00 33 4 79 44 44 96
Mail : eric.lemoine at camptocamp.com
http://www.camptocamp.com
