[OpenLayers-Users] EditingToolbar with Google Base layer
Filipe Silva filipesilva1 at gmail.com
Mon Jul 11 14:37:34 EDT 2011
Hello all.
Im trying to get the coordinates drawn by the drawfeature avaliable in the
EditingToolbar in a google maps base layer-
I´ve created the map with the "sphericalMercator: true," and im transforming
the projection to get the coordinates.
However the numbers returned are far from the truth and even NaN.
>From what ive read its all about the projections and the transforms, but i
cant get it to work.
Below is a working (returning the wrong coordinates) sample code.
Ill apreciate the help.
Thanks
Filipe
<html>
    <head>
        <!-- OpenLayers core js -->
        <script type="text/javascript" src="
http://www.openlayers.org/dev/OpenLayers.js"></script>
        <!-- OpenStreetMap base layer js -->
http://www.openstreetmap.org/openlayers/OpenStreetMap.js"></script>
        <!-- Google Maps -->
        <script src="http://maps.google.com/maps/api/js?sensor=false
"></script>
        <script type="text/javascript">
        function init() {
            var proj = new OpenLayers.Projection("EPSG:4326");
            //Create map
            var map = new OpenLayers.Map('map');
            //Add controls
            map.addControl(new OpenLayers.Control.LayerSwitcher());
            //base layer WITH sphericalMercator
            var gmap = new OpenLayers.Layer.Google("Google Streets", {
                'maxExtent': new OpenLayers.Bounds(-20037508.34,
-20037508.34, 20037508.34, 20037508.34)
            //Vector Layer
            var pointLayer = new OpenLayers.Layer.Vector("Point Layer");
            //add layers
            map.addLayers([gmap, pointLayer]);
            //center map
            var lonlat = new OpenLayers.LonLat(16.373056, 48.208333);
            lonlat.transform(proj, map.getProjectionObject());
            map.setCenter(lonlat, 5);
            //add feature
            var point = new OpenLayers.Geometry.Point(16.373056, 48.208333);
            point = point.transform(proj, map.getProjectionObject());
            var pointFeature = new OpenLayers.Feature.Vector(point, null,
null);
            pointLayer.addFeatures([pointFeature]);
            //add EditingToolbar
            map.addControl(new
OpenLayers.Control.EditingToolbar(pointLayer));
            //attach to events
            pointLayer.events.on({
                "sketchcomplete": OpenLayers.Function.bind(report_1, this)
            //callback function
            function report_1(event) {
                var bounds = event.feature.geometry.getBounds();
                var ll = map.getLonLatFromPixel(new
OpenLayers.Pixel(bounds.left, bounds.bottom));
                var ur = map.getLonLatFromPixel(new
OpenLayers.Pixel(bounds.right, bounds.top));
                ll = ll.transform(proj, map.getProjectionObject());
                ur = ur.transform(proj, map.getProjectionObject());
                alert(ll.lon + ", " + ll.lat + ", " + ur.lon + ", " +
ur.lat);
        </script>
    </head>
    <body onload="init()">
        <div id="map" style="width:500px; height:500px;"></div>
        <div id="coordinates"></div>
    </body>
</html>
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20110711/53217382/attachment-0001.html
