AW: [OpenLayers-Users] custom script creation: Dependencies
Robert Buckley
robertdbuckley at yahoo.com
Wed Jul 13 10:48:20 EDT 2011
In the production app I have the javscript links within the <Body> after
following the yslow recommendations.
here are two apps which should do the job of customizing, but knowing which
classes to use (ie the dependencies) is the problem
http://openlayerer.appspot.com/
http://www.webmapcenter.de/olbuild/makebuild.php
Von: Nicholas Efremov-Kendall <n.e.kendall at gmail.com>
An: Robert Buckley <robertdbuckley at yahoo.com>
Gesendet: Mittwoch, den 13. Juli 2011, 15:23:42 Uhr
Betreff: Re: [OpenLayers-Users] custom script creation: Dependencies
Hi Rob,
Stupid question: are you loading your JS in the head or body? Second, I know
with OL you can do a custom build which only has the functions you need. I don't
know about ext.js, or geoext...
On Wed, Jul 13, 2011 at 1:03 AM, Robert Buckley <robertdbuckley at yahoo.com>
wrote:
>After spending the most of this week reading about optimization of web apps I
>started compiling custom scripts for openlayers, GeoExt.js and Ext.js.
>As this is the openlayers forum i´d like to ask if there is a list/App which I
>can use firstly to check which libraries are actually being used in my
>applications and if there is anything to give an indication of which
>dependencies there are.
>I found the trial and error method of compiling all three API's incredibly time
>consuming and frustrating due to the fact that one can never be sure if the app
>will work after the custom build.This means the normal routine would be
>1. build new script
>2. copy script into directory
>3. debug app ( which entails testing every single function/tool/combination of
>function calls built into the map)
>4. repeat step 3 for IE6. IE7. IE8. IE9, Firefox 3, Firefox4, Firefox5, Chrome,
>Opera
>There must be some programming guru who has thought about this already, or am I
>just doing it wrong. I would assume that most people are pretty happy with the
>long loading times.....but having to wait up to 30 seconds for an app to load in
>IE is not acceptable web practice.
>(btw. Why is IE soooo slow?)
>yours
>Rob
>_______________________________________________
>Users mailing list
>Users at lists.osgeo.org
>http://lists.osgeo.org/mailman/listinfo/openlayers-users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20110713/f4cc9d21/attachment-0001.html
