[OpenLayers-Users] Call a SLD file for a Vector Layer
gbrun gbrun at myopera.com
Mon Jul 18 06:32:04 EDT 2011
Hi list!
I would like to apply SLD styles to my vector layers. It should work like
in this example : http://www.openlayers.org/dev/examples/sld.html
But what I want to do is a little bit different: each layer has its own
style. So I want that each vector layer calls its default style from a
folder in my web application where styles are stored with the same name as
their specific layer. For example, my application has a vector layer named
"vector". In this case, this layer must called a SLD file named
"vector.xml".
The OpenLayers example uses a "OpenLayers.LoadURL()" method. I'm looking
for a different way: I would like to read the SLD response without this
method. It should look like this:
var url_sld = "../sld/"+featureType.name+".xml";
			var format_sld = new OpenLayers.Format.SLD(url_sld);
			processResponse : function (response){
				var sld = format_sld.read(response.responseXML ||
response.responseText);
But it doesn't work. I think, there is something that I don't understand
when I read the SLD response.
Can someone clarify me this?
Geoffrey
Using Opera's revolutionary email client: http://www.opera.com/mail/
