[OpenLayers-Users] WMS-layer moved to the north
Dennis Hesse BAW
baw at dennishesse.de
Tue Jul 19 02:26:48 EDT 2011
Hi Arnd,
Ok, seems clear, but why then is it ok when zooming in? Does the
projection change on higher zoom levels, or is the difference just to
small to see the error?
If you want to see more of these layers, they will be online sometime
in the future at www.mdi-de.org, but it can last for some months, were
just starting ;-)
Dennis.
2011/7/18 Arnd Wippermann <arnd.wippermann at web.de>:
> Hi,
> 1. map creation without options will lead to projection EPSG:4326.
> 2. Google maps etc. can used with EPSG:4326, but data in EPSG:4326 will be
> shifted.
> Use the map options to set your map to spherical mercator (EPSG:900913).
> var options = {
> controls:[], //create map without controls -> add them later
> projection: new OpenLayers.Projection("EPSG:900913"),
> displayProjection: new OpenLayers.Projection("EPSG:4326"),
> units: "m",
> numZoomLevels: 18,
> maxResolution: 156543.0339,
> maxExtent: new OpenLayers.Bounds(-20037508, -20037508,
> 20037508, 20037508.34)
> var map = new OpenLayers.Map('map', options);
> By the way your layers looks very interesting.
> Arnd
> -----Ursprüngliche Nachricht-----
> Von: openlayers-users-bounces at lists.osgeo.org
> [mailto:openlayers-users-bounces at lists.osgeo.org] Im Auftrag von Dennis
> Hesse BAW
> Gesendet: Montag, 18. Juli 2011 15:30
> An: openlayers-users at lists.osgeo.org
> Betreff: [OpenLayers-Users] WMS-layer moved to the north
> Hi list,
> I've got a strange problem.
> I'm just starting with Openlayers, and try to add a WMS-layer to Openlayers
> as an overlay.
> When I open the map, which is located at zork66.de/openlayers/sostest.html,
> both overlays are moved to the north a bit. What is strange to me is that
> when I zoom in some steps the overlays fit to the OSM map and the Bing
> sattelite image.
> Can anyone help me with it?
> Thanks
> Dennis.
> Dennis Hesse
> Bundesanstalt für Wasserbau Dienststelle Hamburg Wedeler Landstraße 157
> 22559 Hamburg
> Tel.: 040 81908-0 E-mail: baw at dennishesse.de
> Webseiten: BAW || MDI-DE
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
Dennis Hesse
Wedeler Landstraße 157 22559 Hamburg
