[OpenLayers-Users] Map layer control
truongxuan quang
truongxuanquang at yahoo.com
Wed Jul 20 08:55:59 EDT 2011
Hello list
I got two layers (let say they are conflict together)
One is:
var Obs_Combo = new Ext.form.ComboBox({
mode: 'local',
value: "rain fall",
triggerAction: 'all',
forceSelection: true,
width: 205,
fieldLabel: 'Title',
hiddenName: 'title',
displayField: 'name',
valueField: 'value',
mode: "local",
store: new Ext.data.JsonStore({
fields : ['name', 'value'],
data : [
{name : 'rainfall', value: 's1'},
{name : 'technical stations', value: 's2'},
{name : 'station group 1', value: 's3'},
{name : 'station group 2', value: 's4'}
//{name : 'hydrological stations', value: 's5'},
Obs_Combo.on('select',
function(combo, record, index) {
var tt; tt=record.get("value");
check(tt);
check_store(tt);
store_data.load();
gridPanel.reload();
store_data.bind(vecLayer_ds);
select2.bind(vecLayer_ds);
this
and the other is as e.g. bellows
function submit()
.......// input data from textbox here
......//input (lat,lon)...etct.
marker.events.register('mousedown', feature, markerClick);
markers=new OpenLayers.Layer.Markers("stations");
map.addLayer(markers);
I have two problems:
1) when I click to the makers on the map, pupup doesn't appear until I turn off
the vecLayer_ds on the tree menu, How could I do in this case, without turn on
and turn off the vecLayer_ds.
2) How can I search for mapLayer name markers and turn it off if I click again
on the submit() function because If I click n time code will do n time of
Please give me a solution, many thanks for reading this msg
Quang
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20110720/12ca3c74/attachment.html
