[OpenLayers-Users] Overlapping WMS Layer Features
Bart van den Eijnden (OSGIS) bartvde at osgis.nl
Tue Jul 26 10:32:51 EDT 2011
This is not something OpenLayers control, OpenLayers just retrieves the
image produced by the WMS.
Maybe you can get the WMS to use a database view with a proper ORDER BY
statement, or do some ordering inside of the SLD if possible.
So you need to look for server-side solutions depending on your WMS
product used.
Best regards,
Bart
> Hello,
> I have a WMS layer I'm displaying, which contains several polygons.
> Notably, there are two polygons that lie completely inside another
> polygon.
> I am unable to see these polygons, only the large polygon that encloses
> them. Is there a way to display these? I want to allow a user to click on
> a
> polygon to display data about that polygon. I'm currently using the
> GetFeatureInfo request to do that, which pulls the data for the hidden
> polygons.
> My layer initialization code is below. Thank you in advance.
> -Pat
> 	var layerToAdd = new OpenLayers.Layer.WMS(name, tileServer,
> 			LAYERS: layerName,
> 			STYLES: '',
> 			TRANSPARENT: true
> 			buffer: 0,
> 			displayOutsideMaxExtent: true,
> 			isBaseLayer: false,
> 			visibility: showOnInit,
> 			opacity: 0.5
> 	map.addLayer(layerToAdd);
> http://osgeo-org.1803224.n2.nabble.com/Overlapping-WMS-Layer-Features-tp6622410p6622410.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
