[OpenLayers-Users] Re: Problems getting WFS layer
Casper Span
info at spatially-oriented.com
Thu Jun 9 10:12:57 EDT 2011
Hi Bart, Mark,
There is nothing related to WFS on the console, nor on NET's XHR subtab.
Even when everything is checked. It's like it crashes before it gets
there... (with no error, ofcourse...) I've also tried your suggestion, Mark.
Still the same.
The DescribeFeatureType:
<xsd:schema xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:gml="
http://www.opengis.net/gml" xmlns:gs="http://casp-geoserver/"
elementFormDefault="qualified" targetNamespace="http://casp-geoserver/">
<xsd:import namespace="http://www.opengis.net/gml" schemaLocation="
http://localhost:80/geoserver/schemas/gml/3.1.1/base/gml.xsd"/>
<xsd:complexType name="locatiedossiersType">
<xsd:complexContent>
<xsd:extension base="gml:AbstractFeatureType">
<xsd:sequence>
<xsd:element maxOccurs="1" minOccurs="0" name="ID" nillable="true"
type="xsd:decimal"/>
<xsd:element maxOccurs="1" minOccurs="0" name="GEOMETRY"
nillable="true" type="gml:GeometryPropertyType"/>
</xsd:sequence>
</xsd:extension>
</xsd:complexContent>
</xsd:complexType>
<xsd:element name="locatiedossiers" substitutionGroup="gml:_Feature"
type="gs:locatiedossiersType"/>
</xsd:schema>
Hmm... I just tried another request from a different pc... now I suddenly
DID get some xhhtp on the NET panel:
REQUEST:
<wfs:GetFeature xmlns:wfs="http://www.opengis.net/wfs" service="WFS" version
="1.1.0" xsi:schemaLocation="http://www.opengis.net/wfs
http://schemas.opengis.net/wfs/1.1.0/wfs.xsd http://casp-geoserver/
http://casp-geoserver/geoserver/wfs/DescribeFeatureType?version=1.1.0&typename=gs:locatiedossiers
" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
<wfs:Query typeName="feature:locatiedossiers" srsName="EPSG:28992"
xmlns:feature="http://casp-geoserver/">
<ogc:Filter xmlns:ogc="http://www.opengis.net/ogc">
<ogc:BBOX>
<ogc:PropertyName>GEOMETRY</ogc:PropertyName>
<gml:Envelope xmlns:gml="http://www.opengis.net/gml" srsName="EPSG:28992">
<gml:lowerCorner>562664.54279097 6811227.9320805</gml:lowerCorner>
<gml:upperCorner>574130.09703169 6820515.0310153</gml:upperCorner>
</gml:Envelope>
</ogc:BBOX>
</ogc:Filter>
</wfs:Query>
</wfs:GetFeature>
RESPONSE:
<wfs:FeatureCollection numberOfFeatures="0" timeStamp="
2011-06-09T16:09:36.265+02:00" xsi:schemaLocation="http://casp-geoserver/
http://casp-geoserver:80/geoserver/wfs?service=WFS&version=1.1.0&request=DescribeFeatureType&typeName=gs%3Alocatiedossiers
http://casp-geoserver:80/geoserver/schemas/wfs/1.1.0/wfs.xsd" xmlns:gs="
http://casp-geoserver/" xmlns:ogc="http://www.opengis.net/ogc" xmlns:gml="
http://www.opengis.net/gml" xmlns:xsi="
http://www.w3.org/2001/XMLSchema-instance" xmlns:xlink="
http://www.w3.org/1999/xlink" xmlns:ows="http://www.opengis.net/ows"
xmlns:wfs="http://www.opengis.net/wfs">
<gml:featureMembers></gml:featureMembers>
</wfs:FeatureCollection>
So basically, it can't find anything... Maybe this is a projection related
issue then... The data is EPSG:28992,
My Map options hash have:
projection: new OpenLayers.Projection("EPSG:4326"),
displayProjection: new OpenLayers.Projection("EPSG:28992"),
Could there be a mixup there? I still find the projection/displayProjection
really confusing... what's the real difference between the two?
regards,
Casper
On Thu, Jun 9, 2011 at 2:33 PM, Mª®k <mc.prins at gmail.com> wrote:
> 2011/6/9 Bart van den Eijnden <bartvde at osgis.nl>:
> > Hi Casper,
> > AJAX requests normally show up in the Console tab of Firebug, make you
> sure
> > you have activated the option to show AJAX requests.
> > Without a request XML and response XML it's really difficult to help you.
> > Otherwise, send us the output of your DescribeFeatureType request, a
> common
> > mistake is that the featureNS does not exactly match the namespace
> > advertized on the WFS.
> my most common mistake here is a trailing slash on the namespace,
> always gets me...
> You might also want to try adding the featurePrefix : 'gs' to the
> options hash (I see you're using that in the schema url).
> Mark
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20110609/9030d3fc/attachment.html
