[OpenLayers-Users] OpenLayer & iPhone
Eric Lemoine eric.lemoine at camptocamp.com
Wed Jun 22 02:02:29 EDT 2011
On Wed, Jun 22, 2011 at 3:03 AM, Noli Sicad <nsicad at gmail.com> wrote:
> Hi Eric,
>>> Any advice on how to improve the performance?
>> You can try <http://www.openlayers.org/dev/OpenLayers.mobile.js>. But
>> as Andreas said you'd be better off creating your own build.
> What is in this OpenLayers.mobile.js aside from TouchNavigation
> control to compare to the regular OpenLayers.js?
The mobile build profile is in the source tree. See
<http://trac.osgeo.org/openlayers/browser/trunk/openlayers/build/mobile.cfg>.
> Is any version of
> this that is not minified?
You can use the buildUncompressed.py script to create a non-minified build.
> Is TouchNavigation control also in the regular Openlayers.js?
What do you mean by "regular OpenLayers.js"?
If you're talking about <http://www.openlayers.org/dev/OpenLayers.js>
or any other OpenLayers.js build hosted on www.openlayers.org then
yes, it includes TouchNavigation.js, it is a full build actually, made
with this profile:
<http://trac.osgeo.org/openlayers/browser/trunk/openlayers/build/full.cfg>.
That is why it is highly recommended to create one's own profiles and builds.
Cheers,
Eric Lemoine
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel : 00 33 4 79 44 44 96
Mail : eric.lemoine at camptocamp.com
http://www.camptocamp.com
