[OpenLayers-Users] WMSGetFeatureInfo + xy mouse coordinates, can this be done?
Andrew Stewart Andrew.Stewart at reddeer.ca
Tue Mar 1 09:39:09 EST 2011
Ok thanks.. So basically if my web service does not support tolerance (which I'm pretty sure is the case) then there is not much I can do with openlayers to fix this problem.. Besides possibly changing my features into markers from my WFS and giving those markers tooltips/hotspots but not sure what the performance would be on that since I need sometimes 50+ markers.
-----Original Message-----
From: openlayers-users-bounces at lists.osgeo.org [mailto:openlayers-users-bounces at lists.osgeo.org] On Behalf Of Alexandre Dube
Sent: March 01, 2011 6:49 AM
To: openlayers-users at lists.osgeo.org
Subject: Re: [OpenLayers-Users] WMSGetFeatureInfo + xy mouse coordinates, can this be done?
That could be setup in your web mapping service. If you use MapServer,
you could set the Layer object definition "TOLERANCE" parameter for that.
Regards,
Alexandre
[1] http://mapserver.org/mapfile/layer.html (search for "TOLERANCE")
On 11-02-28 10:02 PM, Planet)x wrote:
> I have a slight problem which has to do with my WMS mainly but wondering if
> there is a way to program around it. Well problem is I can increase the
> symbol size for points on my Web service but the geometry of the point
> (centroid) remains the same. Therefore when using a
> OpenLayers.Control.WMSGetFeatureInfo the feature info is never returned
> until I move the mouse directly in the middle of the point feature (and also
> lines unfortunately). Question is can I somehow force the mouse to be moved
> to the center of the point when it nears a symbol.. and is there anyway to
> actually get the entire coordinates for the symbol so I can use them to do
> the featureinfo somehow? Not sure if this makes sense or if there is another
> approach I can utilize to do this.. appreciate any advice!
Alexandre Dubé
Mapgears
www.mapgears.com
Users mailing list
Users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/openlayers-users
[This message has been scanned for security content threats and viruses.]
[The City of Red Deer I.T. Services asks that you please consider the environment before printing this e-mail.]
