[OpenLayers-Users] Multiple Styles for grouped vector layerswith multiple featuretypes possible?
Andrew Stewart Andrew.Stewart at reddeer.ca
Sun Mar 6 17:24:19 EST 2011
I am able to use multiple typenames when I define the layer itself like -
 //Grouped AOI layer
           var layer_AOIs_WFS = new OpenLayers.Layer.Vector("Areas of Interest", {
                minScale: 125000,
                maxScale: 99,
                //visibility: false,
                strategies: [new OpenLayers.Strategy.BBOX()],
                 protocol: new OpenLayers.Protocol.WFS({
                 url: wfs,
                 featureType: ["Attraction","Fire_Hall","Community_Shelter"],
                 featureNS: "http://www.intergraph.com/geomedia/gml",
                 featurePrefix: "gmgml",
                 srsName: "EPSG:3776",
                 geometryName: "Geometry",
                 version: "1.1.0"
And then if I add this layer to the map all of the correct layers appear.
So when I used your example code I passed the new array of featureType ["Name 1, "Name 2", etc]
By setting layer_AOIs_WFS.options.protocol.featureType = array_Features;
Then I have tried refresh with force, redraw with force and still the same vector features appear.. So not sure why. I will try to modify some stuff might I have to refresh the map also?
-----Original Message-----
From: arnd.wippermann at web.de [mailto:arnd.wippermann at web.de]
Sent: March 06, 2011 3:20 PM
To: Andrew Stewart
Cc: users at openlayers.org
Subject: AW: [OpenLayers-Users] Multiple Styles for grouped vector layerswith multiple featuretypes possible?
Hi Andrew,
I have to patch the protocol.WFS.v1 to get multiple typenames for one WFS
layer working. From your previous post and the code, I have thought, that
you have got it also working.
If your code works and you get both typenames from your WFS, then I have no
clue, why my code not working for you.
Arnd
-----Ursprüngliche Nachricht-----
Von: openlayers-users-bounces at lists.osgeo.org
[mailto:openlayers-users-bounces at lists.osgeo.org] Im Auftrag von Andrew
Stewart
Gesendet: Sonntag, 6. März 2011 23:10
An: users at openlayers.org
Betreff: FW: [OpenLayers-Users] Multiple Styles for grouped vector
Thanks Arnd, I am trying to use the method of adding/removing featureTypes
from the code example you sent by adding array items to the featureType and
refreshing the layer, except it doesn't refresh. I am changing the
featureType here from "Attraction", "Fire_Hall" to the below but the other
features remain on and the new ones are not added, any idea why>?
    alert(layer_AOIs_WFS.options.protocol.featureType);
    var array_FeatureType = [];
    array_FeatureType.push("Hospital");
    layer_AOIs_WFS.options.protocol.featureType = array_FeatureType;
    layer_AOIs_WFS.refresh({force:true});
Sent: March 06, 2011 6:12 AM
To: Andrew Stewart
You can use a styleMap with context. The WFS response from MapServer look
like
'<ms:LAYER1 fid="LAYER1.WFS, triangle No. 4">'.
The fid contains the typename and OpenLayers set this as feature.fid. If
that apply to other Mapservers, i don't know.
var context = {
    getColor : function (ft){
        if(ft.fid.search(/^LAYER1/)==0)
            return '#00FF00';
        else if(ft.fid.search(/^LAYER2/)==0)
            return '#FF00FF';
        else if(ft.fid.search(/^LAYER3/)==0)
            return '#0000FF';
        else
            return '#FF0000';
Example :
http://gis.ibbeck.de/ginfo/apps/OLExamples/OL29/WFS_with_multiple_featureTyp
es.asp
Arnd
[mailto:openlayers-users-bounces at lists.osgeo.org] Im Auftrag von Planet)x
Gesendet: Donnerstag, 3. März 2011 23:06
Betreff: [OpenLayers-Users] Multiple Styles for grouped vector layers with
 With my below code I have multiple featuretypes grouped into a single WFS
layer and they are both displaying properly. My problem is I need to define
2 different styles one for each featuretype. Can I do it this way somehow or
do I need to modify my code?
//Test Vector Style
   var style_attraction = OpenLayers.Util.extend({},
OpenLayers.Feature.Vector.style['default']);
       style_attraction.externalGraphic = 'sask.jpg';
       style_attraction.cursor =  'hand';
       style_attraction.graphicHeight = 35;
       style_attraction.graphicWidth = 35;
       style_attraction.graphicOpacity = 0.8;
     //Areas of Interest Group
           var layer_AOIs_wfs = new OpenLayers.Layer.Vector("Attraction", {
                minScale: 125000,
                maxScale: 99,
                styleMap: new OpenLayers.StyleMap(style_attraction),
                 url: wfs,
                 featureType: ["Attraction", "Fire_Hall"],
                 version: "1.1.0"
     //Add Vector Layers to Map
     map.addLayer(layer_AOIs_wfs);
View this message in context:
http://osgeo-org.1803224.n2.nabble.com/Multiple-Styles-for-grouped-vector-la
yers-with-multiple-featuretypes-possible-tp6086563p6086563.html
Users mailing list
Users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/openlayers-users
[This message has been scanned for security content threats and viruses.]
[The City of Red Deer I.T. Services asks that you please consider the
environment before printing this e-mail.]
[The City of Red Deer I.T. Services asks that you please consider the environment before printing this e-mail.]
