[OpenLayers-Users] Problem with SelectFeature control
Bob Farrell robertanthonyfarrell at gmail.com
Tue Mar 8 12:37:26 EST 2011
Great - did a build from a trunk checkout and the issue is indeed
fixed. Thanks for pointing it out and sorry for not spotting it in the
issue tracker.
All the best,
On 8 March 2011 17:17, Alexandre Dube <adube at mapgears.com> wrote:
> Hi,
>  This has been fixed in trunk in the past few days.  I just tried with
> current trunk version and get the expected behavior.  See the according
> ticket :
> http://trac.osgeo.org/openlayers/ticket/2812#comment:6
> Regards,
> Alexandre
> On 11-03-08 11:50 AM, Bob Farrell wrote:
>> Hi there,
>> Having great success with OpenLayers but have found one minor issue
>> which may be a bug but hopefully is just a mistake on my part.
>> Firstly, here's my code (or here with highlighting if you prefer:
>> http://bpaste.net/show/SjHd7xV7pZUnJNzYcI89/):
>>         var highlightCtrl = new OpenLayers.Control.SelectFeature(layer, {
>>             hover: true,
>>             highlightOnly: true,
>>             renderIntent: "temporary"
>>         var selectControl = new OpenLayers.Control.SelectFeature(layer,
>>              multiple: true,
>>              toggle: true,
>>              clickout: false,
>>              onSelect: function (e) {
>>                 that._selectedRegions[e.data.id] = true;
>>                 that.changeCallback({id: e.data.id, selected: true},
>>                                     that._selectedRegions);
>>              onUnselect: function (e) {
>>                 that._selectedRegions[e.data.id] = false;
>>                 that.changeCallback({id: e.data.id, selected: false},
>>         this._map.addControl(highlightCtrl);
>>         this._map.addControl(selectControl);
>>         highlightCtrl.activate();
>>         selectControl.activate();
>> The problem I'm seeing is that when I click a region to select it and
>> then click again to deselect it, when I hover back over that region
>> and then back out of it then its colour is restored to the "selected"
>> colour, even though no onSelect event is triggered.
>> Am I doing something wrong here ?
>> Let me know if I can provide any more info.
>> Thanks very much,
>> Users mailing list
>> Users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
> Alexandre Dubé
> Mapgears
> www.mapgears.com
> Users mailing list
