[OpenLayers-Users] Problem using SelectFeature control with externalGraphic + rotation
Planet)x andrew.stewart at reddeer.ca
Tue Mar 8 16:23:56 EST 2011
I am using a selectfeature control that works fine (displays data about
point). However I have declared a stylemap like the following with an
external graphic / rotation -
//Traffic Count
var style_traffic_count =  new OpenLayers.StyleMap({
                     "default": new
OpenLayers.Style(OpenLayers.Util.applyDefaults({
                         externalGraphic:
"http://localhost/WebServices/images/icons/community_shelter.png",
                         graphicOpacity: 1,
                         rotation: -45,
                         pointRadius: 10
                     }, OpenLayers.Feature.Vector.style["default"])),
                     "select": new OpenLayers.Style({
                         externalGraphic:
This works fine, the symbol appears rotated on the map. However now my
select feature control does not work the same. It only works when I hover
the mouse over the original symbol location and it is not taking into
account the rotation of the external graphic. Is there anyway I can fix this
and has anyone run into a similar issue? Appreciate any advice.
Here is my selectfeature control -
 //Traffic Count Tooltip
    info_traffic_count_tooltip = new
OpenLayers.Control.SelectFeature([layer_TrafficCount], {
           hover: true, highlightOnly: true, renderIntent: "temporary",
           eventListeners: { featurehighlighted: showTrafficTooltip}
        function showTrafficTooltip(event){
        var feature = event.feature;
        var label = feature.attributes.fa_LRS_label;
        if (label == null)
        label = '';
        //Display Tooltip
        tooltip.destroy();
        tooltip_aoi.destroy();
	    tooltip_aoi = new Ext.ToolTip({
        html: label,
        dismissDelay: 3000
        tooltip_aoi.targetXY = [(x_pos + -50),(y_pos - 70)];
        tooltip_aoi.show();
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Problem-using-SelectFeature-control-with-externalGraphic-rotation-tp6143569p6143569.html
