[OpenLayers-Users] help reading openlayers documentation
christopher.schmidt at nokia.com christopher.schmidt at nokia.com
Wed Mar 9 12:57:27 EST 2011
In general, 'options' allows you to pass the name of any property
of the object, and it will be set on the object. To figure out what
properties are available for a given object, you can look at the
"Parameters" section for that object.
You can read more about this in our documentation at:
  http://docs.openlayers.org/library/syntax.html#the-options-argument
-- Chris
On Mar 9, 2011, at 12:23 PM, ext Carlos Krefft wrote:
> Dear OpenLayers Users:
> Within the open layers documentation I’ve noticed that “options” is many times used to show that the constructor takes parameters. But where can I get the details for this parameter {object}? How does one know what parameters it accepts?
> For example: below I have put the constructor documentation for OpenLayers.Filter.Spatial. How do I know what parameters I can put within {Object}?
> Creates a spatial filter.
> Parameters
> options
> {Object} An optional object with properties to set on the filter.
> Kind Regards,
> Carlos
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
