[OpenLayers-Users] Problems with layer order
Kempi info at ycc.ch
Thu Mar 10 10:24:22 EST 2011
Hello...
I'am new with openlayers and could make a lot of things. But one thing is
strange and I don't understand it:
If I add my vector layers they are normally all in one svg image. Each layer
has its own g-tag. Thats nice... but if it is so the function on the layer
setZIndex dosen't have any effect. This is logical because the z-index match
on the hole svg-image.
Question 1:
But how can i change the g-tags order in the image if I like to change that
after the initiation process?
Question 2:
If I add a layer after a while, openlayers put them into a separated svg
image. Thats nice because than I can work with z-indexes but the div of that
new svg is greater then the visible part of the svg image. That is the
reason why I can't work with mouseover events on the svg image under the new
svg image I made. How dose the openlayerscript decide when it makes a new
svg image and do I have the posibility to affect the behavior of OpenLayers?
I would be glad to get some help with these questions.
regards
Kempi
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Problems-with-layer-order-tp6158137p6158137.html
