[OpenLayers-Users] Zoom to filtered feature
Ravi Pavuluri ravitheja at ymail.com
Fri Mar 11 09:50:02 EST 2011
Michal,
I am not sure if this answers your question completely. You can try using WFS
which can get the boundary of your feature of interest and then you can code for
zooming to those bounds.
-Ravi.
To: users at openlayers.org
Sent: Fri, March 11, 2011 3:58:47 AM
Subject: [OpenLayers-Users] Zoom to filtered feature
Hi list,
is there possible to perform automatical zoom to feature filtered by CQL
filter?
I have a WMS layer containig parcels and I want to enable some kind of
searching mechanism where user will put parcel number to a form and after
apply it the only searched parcel will be displayed and map view will be set
to this parcel's bounds.
I enabled CQL filtering like this:
                function updateFilter(){
                if(pureCoverage)
                  return;
                var filter = "parcel_number = " +
document.getElementById('filter').value;
                var filterParams = {
                    cql_filter: filter
                mergeNewParams(filterParams);
            function mergeNewParams(params){
                myLayer.mergeNewParams(params);
and after I put parcel number to a form connected with updateFilter()
function and apply it, the only searched parcel is dispayed. My question is
what should I do to enable zooming to the filtered parcel? Is it possible to
retrieve BBOX of a particular feature from WMS layer and then use it in JS?
Thank you in advance for any suggestions!
Michal
View this message in context:
http://osgeo-org.1803224.n2.nabble.com/Zoom-to-filtered-feature-tp6160737p6160737.html
Users mailing list
Users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/openlayers-users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20110311/4b550474/attachment.html
