[OpenLayers-Users] Re: [Users] wmsgetfeatureinfo, wmscapabilitiesstore & treepanel: how to "inject" dinamically layers
Eric Lemoine eric.lemoine at camptocamp.com
Mon Mar 14 02:29:14 EDT 2011
On Friday, March 11, 2011, Andrés Maneiro <amaneiro at icarto.es> wrote:
> Hello,
> I'm having problems integrating treepanel (geoext) and wmsgetfeatureinfo
> (openlayers). See what I'm trying to do:
> 1) load dinamically all the layers avaiable in the WMS. That's pretty
> easy by means of wmscapabilitiesstore. This example is very clear:
> http://api.geoext.org/1.0/examples/wms-tree.html
> 2) show a popup with info when the user clicks over one of the features
> in the map. It's also pretty easy *if* you know previously the layers,
> as this example shows:
> http://openlayers.org/dev/examples/getfeatureinfo-popup.html
> The problem arises when I try to glue this two concepts together.
> As I see, wmsgetfeatureinfo needs to be provided with some layers (or
> map) to query over.
If no layer is provided the control will query all the WMS layers it
finds in the map.
>  But, I want the popup to show only the info related
> to the layers active (the ones with the checkbox on in example 1), so
> hardcoding the names of the layers in my javascript file seems not an
> option.
The control will actually query the *visible* WMS layers only.
If your WMS layers are served by different WMS services you'll need to
set drilldown to true in the control.
Good luck.
Eric Lemoine
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel : 00 33 4 79 44 44 96
Mail : eric.lemoine at camptocamp.com
http://www.camptocamp.com
