[OpenLayers-Users] Re: OpenLayers.loadUrl is not a function
Kris Peterson kris at mapbiquity.com
Fri Mar 18 18:46:23 EDT 2011
Hi Manuel,
It appears there is a slight error in the first line in your territorio.php
file. The line references the OpenLayers.js library via a relative path, but
is missing a period (in the src attribute). Add the period as below and see
if that does the trick (it did on my side).
Good luck. You have a nice looking application.
Regards,
Kris
Kris Peterson
www.mapbiquity.com
View this message in context: http://osgeo-org.1803224.n2.nabble.com/OpenLayers-loadUrl-is-not-a-function-tp6185417p6186415.html
