[OpenLayers-Users] Re: problem with overview map
Christian López Espínola penyaskito at gmail.com
Thu Mar 24 09:42:09 EDT 2011
On Thu, Mar 24, 2011 at 1:45 PM, vrbikdan <vrbikdan at gmail.com> wrote:
> Hi,
> it isn't work too. Everythime, when I set some layer in the overview map, is
> only red rectangle there but any map. And if I use your code, only without
> setting layer, it is still the same as with my code :(
Hi vrbikdan,
Are you reusing some layer for the overview map? Could you try with
layer.clone() instead?
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/problem-with-overview-map-tp6190056p6203954.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
Cheers,
Christian López Espínola <penyaskito AT computer DOT org>
http://twitter.com/penyaskito | http://penyaskitodice.wordpress.com
