[OpenLayers-Users] Re: OpenLayers.Control.ScaleLine : Add a coefficient
mickal mickamusset at gmail.com
Fri Mar 25 14:04:20 EDT 2011
I really would like that it was simple !
But it's not, the map is come from a dxf file ( dxf2shp with qgis ).
So the scale is not respected.
Thx,
On Thu, Mar 24, 2011 at 10:35 PM, Andreas Hocevar-2 [via OSGeo.org] <
ml-node+6205740-1095475097-182549 at n2.nabble.com> wrote:
> I think your map and/or layer configuration must be wrong. Usually this
> kind of problem appears when your map units don't match the projection's
> distance units.
> I'd say there is no need to introduce a coefficient. Check your projection,
> and configure the map or base layer with the according units.
> Regards,
> Andreas.
> On Mar 24, 2011, at 19:03 , Micka wrote:
> > Hey,
> > Well, I've gotten the source code of this module, so now i'm trying to
> add a coeficient K .
> > The goal is to give the possibility to adjust the scaleline.
> > For that, I thought that we can add two function on this module :
> > • float calculateTheCoefficient(float length, int pixels );      //
> length in meter , pixels number of pixels that the length represent
> > • void setTheCoefficient ( float k );
> > The first function will calculate the coefficient with the actual
> resolution and the length/pixels .
> > the second function will save the coefficient for the update function() .
> > What do you think ?
> > My problem, is that i don't know how to do code the first function
> >    update: function() {
> >         var res = this.map.getResolution();
> >         res*= k;
> >         if (!res) {
> >             return;
> >         // convert maxWidth to map units
> >             var maxSizeData = this.maxWidth * res;
> >         // decide whether to use large or small scale units
> >             var topUnits;
> >             if(maxSizeData > 0.1) {
> >               topUnits = this.topOutUnits;
> >             } else {
> >               topUnits = this.topInUnits;
> >         // and to map units units
> >             var curMapUnits = this.map.units;
> >             var inches = OpenLayers.INCHES_PER_UNIT;
> >             var topMax = maxSizeData * inches[curMapUnits] /
> inches[topUnits];
> >             // now trim this down to useful block length
> >             var topRounded = this.getBarLen(topMax);
> >             // and back to display units
> >             topMax = topRounded / inches[curMapUnits] * inches[topUnits];
> >             // and to pixel units
> >             var topPx = topMax / res;
> >             // now set the pixel widths
> >             this.eTop.style.width = Math.round(topPx) + "px";
> >             // and the values inside them
> >             this.eTop.innerHTML = topRounded + " " + topUnits;
> >         CLASS_NAME: "OpenLayers.Control.ScaleLine"
> > On Thu, Mar 24, 2011 at 3:03 PM, mickal <[hidden email]<http://user/SendEmail.jtp?type=node&node=6205740&i=0&by-user=t>>
> wrote:
> > Hi,
> > The scale that the module displayed to me is not right, I mean :
> > 50 pixel => 1000km
> > but in reality :
> > 50 pixel => 100 m
> > is it possible to add a coefficient to this module ?  to adjust the scale
> > that it displayed.
> > Because otherwise I have to change my map, and this process is very long.
> > thx,
> > View this message in context:
> http://osgeo-org.1803224.n2.nabble.com/OpenLayers-Control-ScaleLine-Add-a-coefficient-tp6204219p6204219.html<http://osgeo-org.1803224.n2.nabble.com/OpenLayers-Control-ScaleLine-Add-a-coefficient-tp6204219p6204219.html?by-user=t>
> > Sent from the OpenLayers Users mailing list archive at Nabble.com.
> > Users mailing list
> > [hidden email]<http://user/SendEmail.jtp?type=node&node=6205740&i=1&by-user=t>
> > http://lists.osgeo.org/mailman/listinfo/openlayers-users
> > Users mailing list
> > [hidden email]<http://user/SendEmail.jtp?type=node&node=6205740&i=2&by-user=t>
> Andreas Hocevar
> OpenGeo - http://opengeo.org/
> Expert service straight from the developers.
> Users mailing list
> [hidden email]<http://user/SendEmail.jtp?type=node&node=6205740&i=3&by-user=t>
>  If you reply to this email, your message will be added to the discussion
> below:
> http://osgeo-org.1803224.n2.nabble.com/OpenLayers-Control-ScaleLine-Add-a-coefficient-tp6204219p6205740.html
>  To unsubscribe from OpenLayers.Control.ScaleLine : Add a coefficient, click
> here<http://osgeo-org.1803224.n2.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=6204219&code=bWlja2FtdXNzZXRAZ21haWwuY29tfDYyMDQyMTl8LTY5MzgyMTU0NQ==>.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/OpenLayers-Control-ScaleLine-Add-a-coefficient-tp6204219p6208637.html
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20110325/45dff89d/attachment-0003.html
