[OpenLayers-Users] page resize breaks map?
S2 s2.akira at tin.it
Mon May 30 05:01:30 EDT 2011
On 30.05.2011 10.45, jrom wrote:
> I quickly look at your code.
> Apparently you do not specify a height/width for your map container.
the width/height of the div containing the map is set in custom.css on
the .openlayermap class (line 25).
.openlayermap {
  width: 512px;
  height: 320px;
  margin-bottom: 10px;
i tried to set it on the div directly with
<div class="openlayermap" id="olmapid82" style="width: 512px; height:
320px;">
but no difference.
thanks,
Simon
> Perhaps you should try to force these values with something in pixels.
> It's a nasty solution but you should give it a try to see if it works
> Jerome
> On Mon, May 30, 2011 at 10:19 AM, S2<s2.akira at tin.it>  wrote:
>> Hi Jerome,
>> thanks for taking the time to answer.
>> I tried
>> line 541 of
>> http://s2.31337.it/
>> elm.data('olmap').updateSize();
>> but it seems to have no effect.
>> On 30.05.2011 9.52, jrom wrote:
>>> Hi,
>>> Perhaps you should try a map.updateSize() after content gets loaded.
>>> It will force a map repaint
>>> Jerome
>>> On Mon, May 30, 2011 at 9:17 AM, S2<s2.akira at tin.it>    wrote:
>>>> hello all!
>>>> on http://s2.31337.it/ i have some openlayers maps. the page uses ∞
>>>> scroll,
>>>> so that when the user scrolls to the bottom of the page, older posts are
>>>> loaded automatically.
>>>> when this happens the map breaks (the pictures in the map get somehow
>>>> resized to a wrong size). you can try this yourself simply by scrolling
>>>> to
>>>> the bottom of the page, let the js load some more posts, and then scroll
>>>> back up.
>>>> can i somehow force the map to repaint itself? (i could do that when new
>>>> content gets loaded).
>>>> i tested this with ff4 and ie 8.
>>>> thanks.
>>>> _______________________________________________
>>>> Users mailing list
>>>> Users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
