[OpenLayers-Users] Re: proxy and apache
Greg Allensworth gregor at greeninfo.org
Thu Nov 3 17:21:06 EDT 2011
On 11/3/2011 2:04 PM, Tondo wrote:
> Hi Greg  thank you. I did as you told:
> so this means... there is an error in that script?
> File "C:/_SOFT/Apache2.2/cgi-bin/proxy.cgi", line 43
> print "Status: 502  Bad Gateway"
> SyntaxError: invalid  syntax
It looks like you're running Windows? You probably need some extra
steps: installing Python, then changing that #! line in the script.
Give this document a reading. It should walk you through setting up your
Apache-on-Windows so that it can run that CGI script.
http://www.imladris.com/Scripts/PythonForWindows.html
For a much shorter and simpler test case, try installing this under
/cgi/bin, maybe name it "test.cgi" and see if you can get it to run with
those directions.
#!/bin/env python
print "Status: 200 OK"
print "Content-type: text/plain"
print "It works!"
If you can get that to print "It works" to your browser, then you should
have CGI and Python working well enough to proceed with proxy.cgi
Greg Allensworth, Web GIS Developer
BS  A+  Network+  Security+  Linux+  Server+
GreenInfo Network - Information and Mapping in the Public Interest
564 Market Street, Suite 510  San Francisco CA 94104
PH: 415-979-0343 x302  FX: 415-979-0371    email: gregor at greeninfo.org
Web: www.GreenInfo.org     www.MapsPortal.org
Subscribe to MapLines, our e-newsletter, at www.GreenInfo.org
