[OpenLayers-Users] Open layers with postgis
Hugo hfpmartins at gmail.com
Tue Nov 15 14:58:30 EST 2011
I would suggest to use st_asgeojson to the geometry at the query level.
Then in php, decode the geometry, build a new array with attributes and
geometry, and finally encode everything to json.
Cheers,
Hugo
On Tue, Nov 15, 2011 at 7:13 PM, Robert Buckley <robertdbuckley at yahoo.com>wrote:
> Sounds easy....any chance you could write a tutorial using simple examples
> we could build on?
> yours
> Rob
> *Von:* Adam Eskreis <aeskreis at gmail.com>
> *An:* Nicholas Efremov-Kendall <n.e.kendall at gmail.com>
> *Cc:* openlayers-users at lists.osgeo.org
> *Gesendet:* 19:31 Dienstag, 15.November 2011
> *Betreff:* Re: [OpenLayers-Users] Open layers with postgis
> Hello Aditya,
> I do what you are wanting to do nearly every day at my job.  Here are a
> few tips to help you get started:
> 1.  The first thing you need to do is set up a connection to your
> PostgreSQL database.  Once this is complete, we can get started
> 2.  Next you are going to want to retrieve your data and pass it to the
> frontend.  Assuming you already know how to do a spatial query, I would
> pull whatever data you want from the database, parse it into an array and
> echo it out using json.
> 3.  Once you have your json on the frontend, you just loop through the
> array and plot the data as you need.
> 4.  The geo-data will come back from PostGIS as either Well Known Binary,
> or Well Known Text, depending on how you chose to retrieve it.  WKB is
> faster, but is harder to parse, and WKT has built in support in OpenLayers.
> (have a look at the OpenLayers.Geometry.fromWKT function).  I recommend
> pulling in the data as WKT for starting out, and as you get more familiar
> you can work on writing a WKB parser.
> 5.  If you need help using spatial queries, I would consult the PostGIS
> guide before continuing wiht anything, however the main functions I would
> recommen dlooking up are:
> distance
> within
> contains
> intersects
> astext
> These functions will encompass most spatial queries you need to execute.
> Hope this helps,
> -Adam
> On Tue, Nov 15, 2011 at 8:08 AM, Nicholas Efremov-Kendall <
> n.e.kendall at gmail.com> wrote:
> I have an ajax app the querries mysql and returns the results as GML. If
> you like, I can share the code with you,
> On Tue, Nov 15, 2011 at 2:15 AM, adams <adams at terrestris.de> wrote:
> Oh sorry,
> I apologize, the correct URL is:
> http://www.openlayers-buch.de/beispiele.php
> (@Bart 403 only for you - today because of the football match, thanks
> for the hint)
> Regards, Till
> On 15.11.2011 09:08, Bart van den Eijnden (OSGIS) wrote:
> > Hey Till,
> > that URL gives a 403 forbidden.
> > Best regards,
> > Bart
> >> Dear Aditya,
> >> there is postgis console, which directly displays queries in OL - this
> >> is a tool my colleague made for a german OL manual.
> >> See the stuff here:
> >> http://www.openlayers-buch.de/beispiele/
> >> go to chapter 9 (in germany only, sorry).
> >> You may also download the code from this page.
> >> Regards, Till
> >> On 15.11.2011 08:54, Aditya Kumar wrote:
> >>> Dear USers,
> >>>   I want to display the result of some queries from postgis using
> >>> php.Can
> >>> you suggest me some documentation for this so that I can go through
> them
> >>> and
> >>> make my application?
> >>> Aditya Kumr
> >>> View this message in context:
> http://osgeo-org.1803224.n2.nabble.com/Open-layers-with-postgis-tp6995410p6995410.html
> >>> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> >>> _______________________________________________
> >>> Users mailing list
> >>> Users at lists.osgeo.org
> >>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
> >> --> GO Mobile - jetzt WebGIS auch auf Smartphones <--
> >>        ! Achtung - terrestris hat eine neue Adresse !
> >> terrestris GmbH & Co. KG
> >> Puetzchens Chaussee 56
> >> 53227 Bonn
> >> Germany
> >> Till Adams
> >> Geschaeftsfuehrung
> >> Tel:                 +49 (0)228 / 962 899-52
> >> Mobile:      +49 (0)151 / 25394429
> >> Fax:                 +49 (0)228 / 962 899-57
> >> http://www.terrestris.de
> >> Amtsgericht Bonn, HRA 6835
> >> Komplementaerin:
> >> terrestris Verwaltungs GmbH
> >> vertreten durch:
> >> Hinrich Paulsen, Till Adams
> >> Users mailing list
> 53227 Bonn
> Germany
> Till Adams
> Geschaeftsfuehrung
> Komplementaerin:
> vertreten durch:
> Users mailing list
> Users mailing list
> Users mailing list
> Users mailing list
Hugo Martins
LabNT - ISEGI UNL
Campus de Campolide
1070-312 Lisboa
N 38°43'56.84", W 9°9'35.74"
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20111115/88481768/attachment.html
