[OpenLayers-Users] display an image file in openlayers
Massimo Di Stefano massimodisasha at gmail.com
Tue Nov 15 20:46:01 EST 2011
i'm tring to debug .. but i'm clueless
for now i stored a non working example here :
http://www.geofemengineering.it//data/imdisp.html
it use the graphic layer as used in the open layer image display example but has a mapnik layer too
the result when i switch to the "graphic" layer, is a blank empty canvas
probably the problem is the projection used to display mapnic, i tired with my gif file and i have the same results (blank canvas)
thanks for you help,
--Massimo.
Il giorno Nov 15, 2011, alle ore 5:14 PM, Phil Scadden ha scritto:
> Sounds like syntax error somewhere in your js. I suggest you use firebug
> in firefox or developer tools in Chrome and open the file. Look at the
> console to see what messages are there.
> Notice: This email and any attachments are confidential. If received in error please destroy and immediately notify us. Do not copy or disclose the contents.
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
