[OpenLayers-Users] CGI & apache tomcat
Andreas Hocevar ahocevar at opengeo.org
Sat Nov 19 05:45:54 EST 2011
Do you do this because you want the proxy from the OpenLayers examples
directory to work? There are simpler ways. Either try
https://github.com/chrismayer/JSP-Whitelist-Proxy, or if your
GeoServer is the one that ships with the OpenGeo Suite, try the
built-in proxy.
Andreas.
On Sat, Nov 19, 2011 at 7:19 AM, Shadin <w_ward_W at hotmail.com> wrote:
> I installed geoserver with apache tomcat on the server
> then I could reach my map from my PC "in the same domain"
> also i installed paython 31
> when i follow these instructions:
> http://www.osgeo.org/pipermail/openlayers-users/2009-August/013175.html
> except the second one because i worked on tomcat 6
> then restart the tomcat, it doesn't work !
> it seems like the conf in wrong or something
> although i just did the same as the instructions
> do i miss something here ?
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/CGI-apache-tomcat-tp7010777p7010777.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
