[OpenLayers-Users] display on-the-fly area while drawing a region on the map?
Martin Ouellet geomartino at gmail.com
Tue Nov 22 10:51:43 EST 2011
Hi all,
Currently I used this piece of code to allow the user to draw a region of
interest on the map:
drawControls = new OpenLayers.Control();
 OpenLayers.Util.extend(drawControls, {
          draw: function() {
              this.box = new OpenLayers.Handler.RegularPolygon(drawControls,
              {"done": this.notice}, {sides:4, irregular:true,
           notice: function(geom) {
            // whatever you want it to do after the box has been drawn
            var feature = new OpenLayers.Feature.Vector(geom);
            //afficher la superficie de la zone dessiné
            var bounds = getExtractBounds();
            var ll = new OpenLayers.LonLat(bounds.left, bounds.bottom);
            var ur = new OpenLayers.LonLat(bounds.right, bounds.top);
            var superficieKm =
            $('#message').jGrowl(superficieKm.toFixed(2) + " km²");
Is it's possible to display the area value on-the-fly while the user draw
it instead of after he finished?
Thanks you in advance!
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20111122/241290ce/attachment.html
