[OpenLayers-Users] Error message using mapfish print
Robert Buckley
robertdbuckley at yahoo.com
Wed Nov 23 06:34:43 EST 2011
HI,
Thanks for the reply.
By origin you mean the Gridset?
If the origin is wrong, why are the layers loaded fine in openlayers?
cheers,
Rob
Von: Jana Golinowski <jgolinowski at codematix.de>
An: users at openlayers.org
Gesendet: 12:31 Mittwoch, 23.November 2011
Betreff: Re: [OpenLayers-Users] Error message using mapfish print
> When I export a map which has layers coming from gwc I always get this error in
> the pdf file
> the gwc layers are displayed fine in openlayers.
> java.io.IOException: Error (status=400) while reading the image from
> http://maps.zgb.de/geoserver/gwc/service/wms?
> BBOX=1120223.6%2C6737442.5%2C1125190.8%2C6744216.0&HEIGHT=625&WIDTH=458&
> TRANSPARENT=true&map_resolution=75&VERSION=1.1.1&FORMAT=image%2Fpng&SERVICE=WMS&
> PROJECTION=EPSG%3A4326&format_options=dpi%3A75&LAYERS=zgb%3Atk50&REQUEST=GetMap&
> STYLES=&SINGLETILE=true&SRS=EPSG%3A900913: Bad Request
> Could anyone shed any light on this?
Did you open that url in a browser? I get this error message:
"X,Y values for the tile index were calculated to be {4324.992337158024,
5473.245314723597} which had to be rounded to {4325, 5473} and exceeds the
threshold of 10%. Perhaps the client is using the wrong origin ?"
Greetings, Jana.
Users mailing list
Users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/openlayers-users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20111123/471c66e5/attachment.html
