[OpenLayers-Users] Re: Box from GetFeature control, can this be polygon?
MTrottier marcandre_trottier at hotmail.com
Wed Nov 23 10:13:08 EST 2011
i'm moving foward !
i'm doing my polygon, the request is sent, i got a response and i can define
my callback
with the help of naresh n, i'm doing something like this :
Hello MTrottier,
 To get polygon intersetced area, defind polygon handler in
OpenLayers.control.GetFeature  as follows.
The follwoing is rough code which you can add in
OpenLayers.Control.GetFeature
if (this.poly) {
            this.handlers.poly = new OpenLayers.Handler.Polygon(this, {
                done: this.selectPoly
            }, OpenLayers.Util.extend(this.handlerOptions.poly, {
                polyDivClassName: "olHandlerPolygonSelectFeature"
selectPoly: function (a) {
        var b;
        this.modifiers = {
            multiple: this.multiple,
            toggle: this.toggle
        this.polygon = a;
        b = a.getBounds();
        this.setModifiers(this.handlers.poly.evt);
        this.request(b, {
            poly: this.poly
you need to add select feature function in existing request function i.e.
you need to use geometry intersect function.
Thanks&Regards,
unfortunately, the prototype on initialize (getfeature.js) not working :
OpenLayers.Control.GetFeature.prototype.initialize = function(options) {
is it possible ?
i need to modify "GetFeature.js" directly to take effects
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Box-from-GetFeature-control-can-this-be-polygon-tp6265591p7024678.html
